How do you adjust the clock on the dashboard
Old Sep 17, 2022 | 01:17 PM
slyfox1812's Avatar
Default How do you adjust the clock on the dashboard
I've tried turning every **** on the dash, and having the key in any different position, but it just doesn't seem to do anything. The clock in my dash board is an hour ahead, and I'm not sure how to fix it
Old Sep 17, 2022 | 01:22 PM
UrbanE's Avatar
Default Re: How do you adjust the clock on the dashboard
Pull the stem on the dash, the one on the right towards you
twist left for hours
twist right for minutes
Old Sep 17, 2022 | 01:28 PM
UrbanE has it right, it also takes a very small period of time for the digits to move. IF you hold it against the 'stop' after twisting it will 'scroll' the numbers faster. Have fun!
Old Sep 18, 2022 | 10:06 AM
copperfieldkid's Avatar
You will have another opportunity to use the adjustment procedure November 6 when Daylight Savings ends.
Old Sep 23, 2022 | 12:05 PM
M4rCu5's Avatar
Pull ****, twist left or right for hrs or minutes, if no worky, pull up and push down repeatedly whilst in the twisted position ..
Twist action is supposed to push the carbon(?) pads down to to engage the lower pads to complete the circuit but dust build up often hinders the contacts so they just need a little persuasion is all
Base
Removed Stem
Stem Base
Pulled and twisted right
Pulled and twisted left
Romad
Apr 28, 2022 05:41 PM
ibedoughboy
Dec 24, 2012 11:14 AM
Tee
Nov 14, 2011 05:20 AM
linda50
Dec 11, 2009 07:01 PM
Robzack
Oct 18, 2006 07:07 PM
