Fuel Gauge Issue
Old Nov 7, 2022 | 04:34 PM
mickland's Avatar
Default Fuel Gauge Issue
Hi all, have an issue with my fuel gauge and wondering if any had a similar experience? Recently I switched out my instrument cluster to a second hand one as a number of my LCD displays had died or were displaying partial information. On switching the cluster all gauges and lights work correctly except for my fuel gauge, it now stays in the full position constantly. It was work correctly before the switch, and I believe the sender unit is also working correctly as the fuel light will come on when fuel is low. Could be just a bad gauge in the second hand cluster but I read somewhere that the gauge requires a dealer reset after an instrument cluster change. Anyone know if this is true or had a similar experience with a cluster removal or change?
Old Nov 7, 2022 | 04:39 PM
bluecoupe's Avatar
Default Re: Fuel Gauge Issue
Check the that the left side plug to the cluster is seated correctly, It maybe possible the pins are not aligned properly.
Old Nov 7, 2022 | 05:16 PM
mickland's Avatar
Yeah, I did think of that and disconnected it and reseated the connection, unfortunately with no luck!
Old Nov 7, 2022 | 05:18 PM
Others have replaced clusters and I do not remember them saying the fuel gauge was any problem. The sensor for the gauge is a simple variable resistor in the tank, I fail to see what you would "reset" in relation to the gauge. The wires to the sensor are in connector "C2", there are quite a few other functions in that connector, but only things like door open sensors, etc. Perhaps it could be that you didn't get it plugged in all the way. An "open" to the sensor equals "full", I think "Bluecoupe" may have your answer.
Again, I have never heard of this being a problem before, but I do admit I've never tried changing the cluster.
matchbox_greg
Jun 8, 2022 10:22 AM
druebel1
Aug 1, 2021 09:57 PM
Jim Holian
Dec 15, 2019 05:53 PM
knowit
Jul 12, 2012 08:00 PM
440EFIMOPAR
Sep 22, 2006 10:41 AM
