Door pull handle linkage part
Old Jul 29, 2023 | 04:00 PM
ceasefire's Avatar
Default Door pull handle linkage part
I haven't been able to find a diagram or part number for a small connector (grommet) that I need for my interior door pull handle. The linkage behind the handle connects to a white plastic grommet that's part of the door opening process. The plastic piece is a connector link to the linkage that goes down inside the door. You can see this piece with the outside trim removed. Mine is broken. I need help finding the part #. (availability) thanks
Old Jul 29, 2023 | 04:41 PM
ceasefire's Avatar
Default Re: Door pull handle linkage part
Thought I'd mention: It's a white plastic 'bullet' or 'cone' shaped connector no more than an inch high.
Old Jul 29, 2023 | 05:27 PM
Ronman's Avatar
Mercedes part 1249880978
Old Jul 30, 2023 | 12:12 PM
dcskmail's Avatar
Old Aug 5, 2023 | 06:38 PM
ceasefire's Avatar
Ronman: Thanks for the info. Saved me much time going nowhere to find the part/part#. chris
Old Aug 5, 2023 | 06:39 PM
ceasefire's Avatar
Dcskmail: Thanks for the info and diagrams. Really appreciate it.
Old Aug 5, 2023 | 06:53 PM
ceasefire's Avatar
Default Interior pull handle
Working on my interior door handle and found that the handle rides on a black plastic pin at the bottom. I have nothing on the top half. There must be a pin also. Anyone have a diagram and part # for what I'm missing? thaks
Old Aug 20, 2023 | 07:48 PM
ceasefire's Avatar
Thanks and I now have replaced the plastic connector.. Additional problem with the pull release handle (not the big grab bar). It has a plastic pin on the bottom that the handle rides on. At the top of the handle must be a plastic block with a pin that secures the top of the handle so it doesn't wobble. Whatever it is, mine is gone. Can't find a picture or part number. Help! thanks!
Old Aug 20, 2023 | 07:59 PM
dcskmail's Avatar
The parts maybe the same as the 1999-2003 Mercedes slk check with a auto parts place that handles Mercedes parts here's 3 below
https://www.pelicanparts.com/Mercedes-Benz/index-SC.htm
https://www.autohausaz.com/catalog?v=1417104&page=1
https://www.fcpeuro.com/
Old Aug 21, 2023 | 01:20 PM
ceasefire's Avatar
dcskmail: Thanks for response and for all the leads. I tried all three but could not find the elusive part.
Old Aug 21, 2023 | 01:49 PM
Ronman's Avatar
Looks like the black part comes with the door handle only.
Driver's side: 2027660124
Passender Side: 2027660224
Old Aug 21, 2023 | 04:57 PM
dcskmail's Avatar
I don't know if this is the part you need on the door handle , check it out
https://www.autohausaz.com/catalog?v...age=1&sortby=r
Old Aug 22, 2023 | 01:01 PM
ceasefire's Avatar
On further exploration of pictures of the interior door release handle recess/mounting (part #84328RE) I found that there is a (logical) top pin to the release handle. Looks like it's plastic spring type with the pin on a block that snaps into the top part of the handle. I believe it's either a black plastic square with the locking plastic type spring and pin or it's part of the whole recess (84328RE). If it's part of the whole recess it's broken off and gone to who knows where. If it is a separate part that slides in and locks in place I can't find it listed anywhere or even a parts number or diagram of it. Is it a replaceable part or is it part of the whole casting (84328RE)? Thanks in advance for any help..
Romad
Jan 16, 2023 12:12 PM
rscrogg
Mar 17, 2014 10:13 AM
stelmos
May 22, 2013 10:59 PM
orlando2128
Jun 12, 2012 07:51 PM
DavidDennison
Apr 18, 2012 01:22 PM
