Reversed remote unlock sequence.
Old Nov 23, 2014 | 10:57 AM
Shamrock's Avatar
Default Reversed remote unlock sequence.
Anyone experience problem with remote fob that 1st press unlocks passenger and trunk and 2nd press unlocks driver? Car has been in body shop for replacement of passsenger side door. Thanks
Old Nov 23, 2014 | 11:11 AM
Default Re: Reversed remote unlock sequence.
it is usually the other way around.....haven't heard of this before Maybe they reversed connections somehow....don't know... I had my passenger door worked on, and the only screw up there is they unplugged the air bag without disconnecting the battery which disabled my air bag system all together... I wouldn't think they could cross up connections if they were just working on the door.....
Old Nov 23, 2014 | 11:25 AM
What you have is the normal operation, second press to open the passenger door.
from our absent professor onehundred80 :
Instructions to change the programming you have now.
Press both lock and unlock buttons at the same time and hold them down until the red light at the top of the key fob blinks twice. Repeat this operation and the change to the programming is undone.
Old Nov 23, 2014 | 12:32 PM
Mrmiata's Avatar
George ... his is working a$$backwards.. drivers door doesn't open till second press.. should be the 1st door to open.. second press to unlock all.
Old Nov 23, 2014 | 01:50 PM
Shamrock's Avatar
Thanks. First time posting to forum, so please excuse any screwups on my replies
Old Nov 23, 2014 | 02:33 PM
Thanks Greg, overlooked that.
Weird.
At any rate, maybe making it unlock both will resolve the issue.
Old Nov 23, 2014 | 04:17 PM
Mrmiata's Avatar
Yeah that will keep from pressing twice to get in and drive.. LOL. Wonder if running the re sync might fix it..
Old Nov 23, 2014 | 07:42 PM
Shamrock's Avatar
Resync didn't fix - suspect vacuum lines got swapped when door was replaced. Will post results when I get a chance to check. Thanks for the responses.
Old Nov 23, 2014 | 07:48 PM
I think you solved your problem. That is probably what the body shop did......
Apr 28, 2016 02:04 AM
Mackel
Oct 16, 2015 09:03 AM
o55ie18
Oct 5, 2015 05:50 PM
Selbyl
Sep 26, 2015 04:15 AM
xjken
Sep 13, 2015 10:18 PM
