Help... 2005 crossfire stops, doesn't start
Old Jan 8, 2017 | 05:59 PM
hurricane61's Avatar
Default Help... 2005 crossfire stops, doesn't start
Hi
Occasionally the vehicle stops. The temperature display shows zero, the cooling fan is running at maximum.When I turn contacts , The engine is not spinning. Sometimes after a few attempts, sometimes after 5-10 minutes starting.
can you help me..! Please
Old Jan 8, 2017 | 09:19 PM
Default Re: Help.. 2005 crossfire stops , doesn't start
The engine stopping and the cooling fan running at high speed mean that the "Engine Control Relay" output from the Relay control Module is not getting to the ECM.
THis is almost always a failure in the Relay Control Module. One of two issues is happening:
  • The Engine Control Relay's contacts are bad.
  • The solder somewhere on the board in the Engine Control Relay's path is fractured.
Try this:
https://www.crossfireforum.org/forum...-no-start.html
knoxxxy
23
Mar 22, 2017 08:21 PM
Jacksung
Jan 10, 2017 04:20 PM
Osusannah
Jan 8, 2017 10:27 PM
AlexParra
Dec 29, 2016 06:17 PM
amx1397
Dec 20, 2016 10:18 PM
