Shifting
Old Sep 5, 2018 | 10:56 PM
BLAST*OFF's Avatar
Default Shifting
Just bought a 2005 crossfire and after day 2 of driving the auto trans will not shift out of first and also notice tire pressure light is on and check engine light came on. Thanks for any help
Old Sep 6, 2018 | 07:49 AM
Default Re: Shifting
Welcome to the forum !
Transmission :
1. low fluid
2. check the electrical connector for leaks
3. replace the 'conductor plate'
TPMS light - pretty normal these days - the batterys in the tire sensors don't last much past 10 years.
CEL - go to Advance or Autozone and have them read the codes, or buy yourself a cheap code reader.
Post results back here.
Old Sep 6, 2018 | 06:42 PM
BLAST*OFF's Avatar
posted yesterday 2005 crossfire with automatic trans shifting problems would not shift out of 1st gear , i was advise to get a code reader and post information.. what i found was code po715 input / turbine speed sensor a circuit so could it be a simple replacement of a input turbine speed sensor a circuit.
Old Sep 7, 2018 | 08:11 AM
Actually, that is the "conductor plate" that I mentioned.
Youtube search 722.6 conductor plate for several good DIY's.
You will need a new filter, fluid and a connector replacement .
A lift will certainly help, but it can be done on jack stands.
Here's a good complete kit : https://www.fcpeuro.com/products/mer...on-service-kit
Lumpacy
Dec 7, 2005 09:39 AM
CrossnJag
Oct 18, 2005 01:42 PM
sailorjoe
Feb 26, 2005 10:18 PM
pdqwrx
Jan 4, 2004 12:24 PM
Rwright2
Nov 2, 2003 01:31 PM
