KYB shocks front
Old Sep 1, 2024 | 12:19 AM
woo78n86's Avatar
Default KYB shocks front
Hello everyone, I have a question on installing front shocks. Do you install a rubber bushing on the top of shocks before putting it in the car? Or do you use the old stuff off the old shocks?
Thanks Terry
Old Sep 1, 2024 | 08:49 AM
copperfieldkid's Avatar
Default Re: KYB shocks front
For better responses : Wheels, Brakes, Tires and Suspension
Old Sep 2, 2024 | 01:01 AM
Thanks Terry
In the future you would get more responses if you ask your questions in the proper category as copperfieldkid mentioned.
I replaced my shocks with a different brand than KYB.
I have included pictures from a post I did when I removed my old shocks and when I installed them.
There is a rubber grommet that goes on the shock itself. There is another thicker grommet that goes on the inner fender well in the engine compartment. I don't know if KYB installs the same as mine, but maybe the pics will help.
Old Sep 2, 2024 | 09:07 PM
woo78n86's Avatar
Hello, thanks for the information, I really didn't know I had to put in a category, but it makes sense. So, I went ahead and put KYB back on it. But the new ones have 280 lbs. of pressure in them. I'm just not that strong to collapse them. So, I'm going to check with my tire dealer and see if they will put them on, So when I post a question, I'm supposed to use daily threads.
Old Sep 3, 2024 | 12:27 AM
The way I did mine was I pulled the shipping strap to the side and put the first rubber grommet on. Then I compressed the shock and put the shipping strap on. I bolted in the bottom mount first. Then I cut the strap and guided the shock into the hole.
The problem with doing that with yours is the pressure as you mentioned.
You don't have to put it in a category, but you will get faster and more replies that way.
Best of luck to you
Old Sep 4, 2024 | 10:43 PM
woo78n86's Avatar
Ok thanks for getting back to me, Yes these shocks didn't come with those straps. I put KYB on my 86 corvettes many years ago, yes, I still have the car my wife owns a 1978 pace car that we've sense 1991.So these shocks came with some large rubber bushings to put on first to install next to the body under the car so confusing there. It also is showing using the top rubber bushing that came on the car to use that, So my son is helping me get it done. I just removed the air filters there the original ones, and the plugs looks they've a very long time also. Thats, ok I like the challenge.
Old Sep 6, 2024 | 02:21 AM
A few tips that will make your life easier when changing the spark plugs;
The night before you change them, if you have an air compressor, blow out the area around each spark plug. Then spray penetrating oil around them.
Spray penetrating oil again the day you replace them.
Recommended tools (These are worth every penny!)
Spark plug boot puller:
Spark plug boot puller Spark plug boot puller
Spark plug swivel socket:
Magnetic Spark plug swivel socket Magnetic Spark plug swivel socket
I've included some pics from a post I did. I hope that this was helpful.
I have a lot of how to posts in my series - My Journey with my 2006 Roadster "Svengoolie"
Old Sep 7, 2024 | 07:34 PM
woo78n86's Avatar
Ok, I got the shocks put on today, my son helped me and this car really rides nice. Missing a rubber pad where jack it up. Anyone known where to get one.
Old Sep 8, 2024 | 03:36 AM
I'm glad that you got the shocks in.
@woo78n86 For the Jack Pads, you can try e bay, or put a "wanted" in the market place page, or you can try an online salvage yard.
You can check this one for availability:
Jack pad
Old Sep 9, 2024 | 08:15 PM
woo78n86's Avatar
Ok I've surfing the internet for this sill jack button pn 5099715AA, I found a place moparonlineparts,com. Has anyone done business with them? Does a bolt hold it on?
Thanks Terry
I also ordered the wrench and the magnetic socket, I also ordered a set of new plugs DENSO plugs 5303. I also believe there all the original.
Joliet John
Apr 15, 2022 03:56 AM
phil alvirez
60
Sep 19, 2021 05:28 PM
jediracer
18
May 23, 2014 06:15 PM
daithi2
Oct 27, 2011 02:57 PM
cmz
Sep 7, 2009 04:51 PM
