Referred by my MB mechanic Lady in distress
Old Oct 8, 2021 | 12:17 PM
Ms Kitty NJ's Avatar
Question Referred by my MB mechanic Lady in distress
Recently purchased 2008 Crossfire 18,599 miles. When car arrived from AL, all was fine no idiot lights on. Battery went dead shortly after arrival. Now the airbag light is on. I work for Mercedes and have 2 techs that service my 2007 Crossfire which now has 202,000 + miles and still is running like a champion, no engine or transmission issues. Tire replacement has been my most $$$ item for the 07. Victor, the tech working on the airbag light issue suspected the clock spring so he changed out the clock spring from 07 to 08 and then he cleared codes. The the airbag light is still on and there are 2 or 3 faults that he is unable to clear with his computer. I told him about the forum and he suggested I put it out there to see if there is anyone in the central NJ area that has a computer that can clear the faults he cannot. Car is currently in the Little Silver area. I see in the Crossfire store they have 2 OBDII CANBUS Code Readers for sale. Any thoughts on if one of those readers would work for this specific issue? Thanking you all in advance for any help or suggestions you can offer. I really don't want to have to go to a Chrysler dealer!
Old Oct 8, 2021 | 12:32 PM
Ronman's Avatar
Default Re: Referred by my MB mechanic Lady in distress
I am not sure why he thought the clock spring was the problem with an airbag light. Clock spring issues I believe would trigger a BAS/ESP light. Is he reading the car as a SLK320 with the STAR/DAS or whatever it is called? I've had luck with the Autel MD802 reading all codes even some better than a DRB3 emulator. Others I believe have had luck with the CRP 123.
Not telling us what codes he is reading does not give us enough info.
Old Oct 8, 2021 | 12:39 PM
Hi Ronman,
Will get more info ie: faults he did show me them on his personal computer, he has his own shop outside of MB. He was reading it as a Crossfire on the computer.
Thanks for your quick reply.
zip439's Avatar
AND DO NOT TAKE IT TO A CHRYSLER DEALER!!!!! 99% of them can not read the Crossfire codes because their new scan equipment is not compatible with the Crossfire and it will cost way too much money for nothing.
Old Oct 8, 2021 | 12:43 PM
Zip439 thanks for reinforcing my feelings about the Chrysler dealer idea!
Old Oct 8, 2021 | 01:51 PM
MI1XFIRE's Avatar
FYI Chrysler had an airbag recall on 2008 models.
Old Oct 8, 2021 | 02:14 PM
Hi MI1XFIRE,
Airbag according to vehicle history was replaced before I purchased. Was aware of the recall as my 07 Xfire was in the recall.
Thanks.
Old Oct 8, 2021 | 02:46 PM
MI1XFIRE's Avatar
If my memory serves me right, I remember instances of airbag light coming on after recall. Apparently some dealers didn't have the proper tool to reset the system after replacement of the airbag.
Old Oct 8, 2021 | 02:49 PM
Thanks will keep that in mind once other avenues exhausted. DO NOT WANT TO GO TO THE DEALER $$$
Have a great weekend.
MKNJ
nickwe21
Nov 16, 2020 03:17 PM
Goldwing
Oct 23, 2019 01:45 PM
elbailey23
31
Oct 12, 2018 06:49 AM
herronn1995
Nov 8, 2011 08:30 AM
Trixie
Nov 21, 2010 12:13 PM
