Other Vehicles The place to talk about watercraft, boats, trains, planes and anything with an engine that isn't a car.
motorcycle problem
Old 05-09-2008, 05:27 AM
manisusmc's Avatar
Default motorcycle problem
my honda shadow is sputtering really bad under load at high rpm, it revs great in neutral, but while in gear it cuts back to the point of all most shutting off the higher the rpm's, my top speed was around 100. now it's 50 at best. anybody know what it could be?
Old 05-09-2008, 06:33 AM
spensley's Avatar
Default Re: motorcycle probelm
Make sure you're getting a good spark - check the leads.
Start with the simple, easy and cheap stuff first.
Old 05-09-2008, 08:19 AM
Administrator / Senior Member
Gummed up carburetors can cause this too.
I had a Magna and that was the problem.
I also had a KZ650 and had one bad coil.
Only ran on two out of four cylinders
Old 05-09-2008, 12:21 PM
Steve - UK's Avatar
Cool Re: motorcycle probelm
Hi,
1: Check the spark plug gaps, if the gap is too small it will run ok at low revs but stutter and missfire at high revs.
2: Check that the float or needle valve in the carburettor is not sticking. If it doesnt open properly, fuel starvation happens at high revs under load.
3: Does it have a choke for cold starting. It it sticking on, this causes rough running in the higher rev range.
4: It there an in-line fuel filter that needs cleaning out, it maybe starved of fuel.
5: Does the fuel filter inside the tank need cleaning, again fuel starvation.
6: Check out the air filter, might be choking her.
Good luck mate!
Steve
Old 05-09-2008, 01:07 PM
mrphotoman's Avatar
yeah i was going to say check out the exhaust and the air filter to make sure they are not clogged and then check the carbs
Old 05-09-2008, 03:06 PM
manisusmc's Avatar
Hi,
Good luck mate!
Steve
yeah i've messes with it all day and checked all that except for the carb so im taking it to the shop next week, thanks, it just blows my mind that i rode all day the day before and then BAM it goes to hell, but i guess somebody got to help keep the motorcycle shop in the green.
Old 05-18-2008, 02:34 AM
Default Re: motorcycle problem
Did you by chance change your pipes and have the carbs re-jetted?
Old 05-18-2008, 06:35 PM
manisusmc's Avatar
I guess a little water got into my gas, because it just cleared itself up and she's runnin fine.
franklindm
03-14-2020 12:23 PM
eikon
09-09-2019 10:16 PM
jimf
10-10-2015 10:22 AM
Abaton6
09-24-2015 10:14 PM
Den656
09-23-2015 12:27 PM
Quick Reply: motorcycle problem
