FS: N/A Upgrade 72mm Throttle Body, Elbow and Larger MAF housing
Old Jan 15, 2014 | 05:17 PM
MatchAG's Avatar
Default FS: N/A Upgrade 72mm Throttle Body, Elbow and Larger MAF housing
I had this setup on my N/A for a month or so before I bought my SRT. Works great. You'll need to use your current MAF sensor. The one that came with this housing was for a V8. $115 delivered plus 3% if using Paypal.
Thanks,
Mark
Old Jan 15, 2014 | 09:53 PM
csteve0355's Avatar
Default Re: FS: N/A Upgrade 72mm Throttle Body, Elbow and Larger MAF housing
Thanks,
Mark
Does this set up fit to the stock air box?
Old Jan 15, 2014 | 09:58 PM
Mrmiata's Avatar
Unless he's got some trick setup..which is unlikely.. you should be good. Fair price for all the parts too..
Old Jan 16, 2014 | 12:07 AM
MatchAG's Avatar
Thanks Mr Miata, mine is the usual setup. Yes, it should fit fine even though I never used it that way. I believe the MAF housings are only different on the inside diameter. The elbow is the same size as stock but I bought it in case I wanted to play around with removing screens, baffles etc.
Old Jan 17, 2014 | 04:37 PM
mobilefitt's Avatar
Ill take it. PM me
Old Jan 18, 2014 | 01:25 PM
MatchAG's Avatar
I sent you a PM. Thanks
Old Jan 19, 2014 | 01:18 PM
MatchAG's Avatar
Item is still available.
Old Jan 20, 2014 | 01:28 AM
mobilefitt's Avatar
Money sent!
Old Jan 20, 2014 | 11:47 AM
MatchAG's Avatar
Item sold. Thanks for those who were interested.
Old Jul 10, 2014 | 01:19 PM
cg80's Avatar
I need to clarify:: prior to installing my 74mm throttle body...do I need to purchase the MAF housing for the 74mm?...Thanks for any advice/help...Carl
This installation is for a 2004 N/A
Old Jul 10, 2014 | 07:02 PM
Mrmiata's Avatar
No Carl.. you can install the throttle body and use oem to finish installation. Would advise getting the larger housing later for full benefit of 74mm. later buddy..:-)
Old Jul 10, 2014 | 08:41 PM
Thanks,
Mark
It has been stated and I have no idea if it is true, but charging someone to use PayPal is against PayPal terms of use. It is also looked down upon as a poor business practice.
When you know how much you want for something add the 3% and put that price down.
In your case $120 would be fine for PayPal use, and you can put down $115 if using cash or check. That looks a lot better.
Old Jul 11, 2014 | 12:25 PM
xfireon20z's Avatar
I think paypal does poor business being greedy!
RamblinShamblin
Aug 12, 2017 10:55 PM
ayebb
Sep 18, 2015 03:35 PM
cppeabody
Sep 15, 2015 08:43 AM
Sep 13, 2015 02:12 AM
steps
Sep 3, 2015 07:24 PM
