Racing The place to talk about autocrossing, road and drag racing.
Drive Shaft Loop Needed to Drag
Old Dec 2, 2010 | 12:47 AM
psuperti's Avatar
Question Drive Shaft Loop Needed to Drag
Planning on going to San Antonio Raceway (IHRA). All cars running faster than 13.99 need a Drive Shaft Loop. Please help me find one for the crossfire? Weld on or bolt on? I would like something light weight, painted etc.
"The NHRA requires all cars that run 13.99 or faster to have a drive shaft safety loop that meets general regulation number 2:4."
Why driveshaft safety loops? In case of u-joint or driveshaft failure, driveshaft safety loops keep the driveshaft from whipping.
Old Dec 2, 2010 | 02:52 AM
MikeR's Avatar
Default Re: Drive Shaft Loop Needed to Drag
Is it NHRA or IHRA? Your quote has NHRA. I run at a NHRA track and they don't require the drive shaft loop..... and I am well below 13.99...
Does the one in your pic not fit the Crossfire?
Old Dec 2, 2010 | 03:57 AM
rcompart's Avatar
You already have them. They are not loops per say but I can tell you after destroying a driveshaft, nothing is getting out of the tunnel with the safety plates bolted in. There are two of them, one for the front half of the driveshaft and one for the rear. Take your vehicle to a shop, put it on a hoist and take pictures. They might let them count and if they don't, explain to them that a drive shaft hoop will offer no more protection than what is already on vehicle. Or tell them you installed driveshaft hoops and when they see the little bars going across, they might not be the wiser.
Old Dec 2, 2010 | 04:55 AM
psuperti's Avatar
Thanks for the posts! The track is IHRA.
I'm away from my car until APR, but I'm getting things ready. I have to get a nitrous bottle blow-off cap as well. Do I need anything else? Do you guys have a picture of the Drive Shaft?
Old Dec 2, 2010 | 06:31 PM
They have (NHRA) (IHRA) never said anything to me...of course I was just test/tuneing....at both tracks...
Old Dec 2, 2010 | 11:05 PM
cruzinquick's Avatar
No you don't. I'll try to find my NHRA rule book but not for our cars. I've raced at Divisionals which is like a 5 state race and my car always passed tech fine.
Old Dec 2, 2010 | 11:14 PM
psuperti's Avatar
Good, I dont want to add 10 LBS of steel to my car anyways. If I got to the test and tune night, most likely they won't inspect me right?
Old Dec 3, 2010 | 01:55 AM
No you should fly through tech pretty easy unless it has something to do with your NOS. Not one tech guy notices our lug bolts are not studs with lug nuts. That's the most obvious violation that our cars factory have. Not much you can do about that.
Old Dec 3, 2010 | 10:18 AM
daithi2's Avatar
when we went to a shootout in OK, the tech inspector got us for wheel studs and blowdown tube. we removed the bottle and got the wrench and showed him they were lug bolts. He'd never seen wheels held on with bolts, reguardless we passed tech. And ive had a tech look at the driveshaft and pass it with oem equipment
Old Dec 4, 2010 | 12:13 AM
psuperti's Avatar
That's nice! I really don't want to drive 3 hours to the track to have them send me home because of these rules. The NX nitrous bottle cap is only $30. Any body else had this?
Old Dec 6, 2010 | 04:29 AM
psuperti's Avatar
bump, who knows about the rules?
Old Dec 6, 2010 | 07:48 PM
Here you go http://www.nhra.com/tech_specs/sport...C_Rulebook.pdf
It's a 2008 rule book but the driveline section is the same. I'm still looking for my 2010 paper rule book. 13.99 and quicker only if your running slicks. Which you aren't running slicks, drag radials are not slicks. 11.49 or quicker if running street tires. Which you are not going to run under 11.49.
On this pdf it's on page 35.
Old Dec 6, 2010 | 07:53 PM
kolevski's Avatar
You never know
Old Dec 6, 2010 | 08:05 PM
Originally Posted by kolevski
You never know
Unless he's adding a huge shot of NOS and a flux capacitor I don't see it happening.
Old Dec 7, 2010 | 12:21 AM
psuperti's Avatar
I got the Mercedes Benz Anti-gravity Switch from the 2011 catalog. My car will be equivalant to 1000 lbs!
Old Dec 7, 2010 | 02:26 PM
Oh with that mod then you better count on getting that loop installed
Old Dec 7, 2010 | 03:22 PM
waldig's Avatar
Talking Re: Drive Shaft Loop Needed to Drag
Sorry Super, the weight has NO effect. The mass and thus the interia is the only thing that matters, helium filled car would add to you mass and slow you, not assist you. Woody
Ok the mass of helium is less than the atmosphere, but less weight only helps because mass and inertia are interconnected in this universe.
Woody
Old Jan 25, 2011 | 11:25 PM
brian_omeara07's Avatar
Woody
I missed you Woody. That is all.
Old Apr 10, 2011 | 02:19 PM
psuperti's Avatar
Got the blow dow tube and pressure valve done! $79 for NX parts = labor.
Old Sep 10, 2011 | 10:30 PM
akakaz2's Avatar
when i raced my mustang a driveshaft loop was needed when you ran slicks not street tires
Kodebuster
Nov 5, 2020 04:06 PM
amx1397
Jan 24, 2016 02:12 PM
tom2112
Dec 1, 2015 09:02 AM
tom2112
Jul 28, 2015 08:12 AM
grip grip
Jul 4, 2015 12:36 AM
