Racing The place to talk about autocrossing, road and drag racing.
Any benefits to pulling fuses / 1/4 mile
Old Sep 12, 2013 | 04:30 PM
velociabstract's Avatar
Default Any benefits to pulling fuses / 1/4 mile
I was going over my notes from the track and realized that when I trans brake hard the computers seem to get confused and result in a slow 60'. Now I'm wondering if pulling the fuses for traction control and ABS/BAS would allow me to launch harder from a slightly higher RPM. I see that Anthony has managed a great 60' while I'm usually in the 1.8xx range. I've only managed one 1.7xx in my Crossfire. Who's tried, what was the result, do I get my hopes up or not. I'll most likely try for myself no matter what the answer is, like I usually do, but a heads up is always nice.
Les
Old Sep 12, 2013 | 04:50 PM
grip grip's Avatar
Default Re: Any benefits to pulling fuses / 1/4 mile
I've never pulled a fuse, and I stall it up to 1,200-1,400 RPM's.
Old Sep 12, 2013 | 04:59 PM
Me too, 1200 to 1400 so as not to waste a pass. I'll give it a go with the fuses pulled and see what happens. If I can get closer to 1800 or 2000 it may have benefits. I'm sort of thinking it's the TCU that's the hick in the up. (fly in the ointment?)
Les
Old Sep 12, 2013 | 05:06 PM
As I understand it, Traction conrol never really goes off. Even if you shut it off. I think the yaw sensor and some anti slip function will still occur has you spin the rear wheels. Just guessing but logic dictates you might have something here.
Wortha try. I'm anxious to hear the outcome.
Old Sep 12, 2013 | 05:11 PM
grip grip's Avatar
Les
1,800-2,000 RPM's, they call that a burnout.
Old Sep 12, 2013 | 05:21 PM
I'm sure the old timers have tried but the old timers are all gone! Time for some newer old timers to plow the same field and post the results. I'm just looking to get all there is. Adding boost isn't the answer ... it seems.
Les
Old Sep 12, 2013 | 06:54 PM
sk8erjosh09's Avatar
Les
Especially if TC is interfering lol.
I wonder if it's kicking in ever so slightly. Maybe not enough to feel it but that it's staying ready to engage? Not sure, just thinking out loud. Very interested in what you find out!
Old Sep 12, 2013 | 07:51 PM
It's not kicking in at 1200 to 1400. When I load the converter to the point that the rear tires start chirping the car reacts badly. I can't really say exactly what it does but it seems "confused". I've felt the same confusion on the road course while braking to keep the front tires loaded and being on the gas at the same time. (yes, you can go faster that way in certain situations) When you get to a certain point where the computers don't have a clue what's going on, power gets cut until things make sense again.
Truthfully, I don't think pulling fuses are going to make a difference because I'm thinking it's TCU related. I'm guessing here, so it's time to try it. If the hurricanes leave us alone, the 28th of september is fuse day.
Les
Old Sep 13, 2013 | 07:26 PM
MJPowers's Avatar
I do some left-foot braking during autocross, and you are good for up to about a second, then the computer cuts the fuel.
Old Sep 13, 2013 | 09:24 PM
I have to wonder if tuners could alter than.
Old Sep 16, 2013 | 06:19 AM
ImportLabSRT's Avatar
I pull the fuses, but my car is quite a bit different than the rest. I set the line-lock for a 1st and 2nd gear burn out and then launch off the 2-step and foot brake at 2500rpms. If I tried either of those with the the ESP fuses still in, the car gets confused and closes the throttle plate and pulsates the brakes.
Kodebuster
Nov 5, 2020 04:06 PM
Hoppy
Dec 7, 2018 07:36 AM
northwest_crossfire
May 30, 2016 05:19 PM
BrenLW
Aug 5, 2015 04:53 AM
grip grip
Other Cars Etc
Aug 1, 2015 09:18 PM
