Racing The place to talk about autocrossing, road and drag racing.
First thing for better 1/4 Mile
Old Apr 7, 2014 | 12:10 PM
UK-John-SRT-6's Avatar
Default First thing for better 1/4 Mile
Ok dont shoot me 180
used the search engine and struggled
what would be the first thing to do for intended 1/4 mile runs?
Old Apr 7, 2014 | 12:32 PM
Default Re: First thing for better 1/4 Mile
sorry in correct post
Old Apr 10, 2014 | 11:33 PM
itsky's Avatar
A dual cold air intake would be my first recommendation. The engine will have much better air flow. After that, I recommend an ECU tune and a smaller supercharger pulley.
Old Apr 11, 2014 | 07:15 AM
JimmieC's Avatar
If you are all about the 1/4 mile I would start with the Wave Trac unit to get it to stop spinning the wheels.
Old Apr 11, 2014 | 07:54 AM
That is the biggest bucks spent in proportion to the gain wouldn't you say?
Old Apr 11, 2014 | 08:05 AM
Padgett's Avatar
Go on a diet ?
Old Apr 11, 2014 | 09:38 AM
JHM2K's Avatar
Instead of listing things for you to buy, 90% of drag racing is the "driver mod". Of course, modifications that increase horsepower will help you once you get rolling, but the trip past the 60' mark is the easiest part. The "skill" in drag racing is all placed on the line within the first ~2 seconds.
Learn to launch the car properly, and then you'll be able to put the "power adders" to good use.
Some simple tips from a (not so hardcore) racer:
  • If your track has a "water box" (to facilitate burnouts), avoid it. Simply drive around it, and don't bother with reversing into it like the cars that are running slicks. Street tires gain NOTHING from the water box burnouts, because the water will stay in the treads. As you stage, the water has time to trickle down to the asphalt. And the moment you try to launch... you'll spin.
  • Avoiding the water box, simply do a quick standing burnout on the portion of the track behind the staging lights. All you want to do is "scrub" the tires... leave the smoke shows to the chaps trying to impress their girlfriends in the stands
  • As you stage, you'll see the lights queue up. Once the second staging light is lit, you'll see the tree countdown within seconds.
  • Once the LAST yellow light is illuminated, start to launch. By the time your brain can communicate to your right foot, and all of that process is manifested in the car actually moving forward, the green light will have been lit and (if timed right) you will have a VERY tidy start to the race
  • Don't jab the throttle -- ROLLLLLL into the throttle. Our cars are VERY sensitive to throttle input in 1st gear, and it only gets worse as you add horsepower.
  • Stay on the throttle until you clear the finish line... and then gradually begin to brake, being careful to bring the car to a halt quickly but not SO quickly that you upset the balance of the car.
  • Collect your time slip, prepare to be annoyed at the slow time, and then return to the lineup for another run
Cheers,
Old Apr 11, 2014 | 04:29 PM
Originally Posted by jhm2k
instead of listing things for you to buy, 90% of drag racing is the "driver mod". Of course, modifications that increase horsepower will help you once you get rolling, but the trip past the 60' mark is the easiest part. The "skill" in drag racing is all placed on the line within the first ~2 seconds.
  • if your track has a "water box" (to facilitate burnouts), avoid it. Simply drive around it, and don't bother with reversing into it like the cars that are running slicks. Street tires gain nothing from the water box burnouts, because the water will stay in the treads. As you stage, the water has time to trickle down to the asphalt. And the moment you try to launch... You'll spin.
  • avoiding the water box, simply do a quick standing burnout on the portion of the track behind the staging lights. All you want to do is "scrub" the tires... Leave the smoke shows to the chaps trying to impress their girlfriends in the stands
  • as you stage, you'll see the lights queue up. Once the second staging light is lit, you'll see the tree countdown within seconds.
  • once the last yellow light is illuminated, start to launch. By the time your brain can communicate to your right foot, and all of that process is manifested in the car actually moving forward, the green light will have been lit and (if timed right) you will have a very tidy start to the race
  • don't jab the throttle -- rollllll into the throttle. Our cars are very sensitive to throttle input in 1st gear, and it only gets worse as you add horsepower.
  • stay on the throttle until you clear the finish line... And then gradually begin to brake, being careful to bring the car to a halt quickly but not so quickly that you upset the balance of the car.
  • collect your time slip, prepare to be annoyed at the slow time, and then return to the lineup for another run
cheers,
brilliant :d
Hoppy
Dec 7, 2018 07:36 AM
BrenLW
Aug 5, 2015 04:53 AM
grip grip
Other Cars Etc
Aug 1, 2015 09:18 PM
XFIRED-TX
Jul 17, 2015 11:56 AM
XFIRED-TX
Jul 14, 2015 10:48 PM
