fan control module?
Old Jul 1, 2018 | 04:47 PM
CapnRon's Avatar
Default Re: fan control module?
My fan isn't running... checked it with battery charger... it spins up.
Found a used FCM on evilBay... be here on the 9th.
Need to bypass somehow for now as we need transportation for short trips around town until the part comes in.
Any ideas...?
Old Jul 1, 2018 | 05:42 PM
You might try wiring something like a headlight bulb in series, but DO NOT wire the fan directly.
Old Jul 1, 2018 | 07:24 PM
CapnRon's Avatar
Not really sure what you mean. More specific please...?
Old Jul 1, 2018 | 07:33 PM
Me neither, forget what I said - that won't work. You need a PWM ( pulse width modulation ) type controller to control the fan, that is what the fan module does.
Old Jul 1, 2018 | 08:05 PM
CapnRon's Avatar
Seems this thing is not able to be bypassed then...
Any luck servicing one of these modules to refurb status...? Process...? Anybody...?
I've got the used one on the way... but that's 8-9 days out.
I think I'm gonna hand it off to my guitar tech and let him tear into it. He's an electronics guru deluxe.
Maybe he will come up with something to contribute to the community here.
Old Jul 1, 2018 | 08:19 PM
Jon2211's Avatar
You have checked the fuse by swapping them over?.
Old Jul 1, 2018 | 08:21 PM
Jon2211's Avatar
Originally Posted by GregWork
In this box above the passenger front wheel.
Attachment 40261
50A (Radiator Fan & Traction Control)
Mopar: 05135816AA
05135816AA Mopar NONE FUSE $3.97
FUSE. 50 AMP. Relays, Fuses, Boxes and related items made by Mopar. #05135816AA
this is the fuse box you are looking for
Old Jul 1, 2018 | 08:42 PM
CapnRon's Avatar
F2 - 50A... fuse was removed and tested... it's good.
Fan was disconnected and tested... it's good.
Old Jul 8, 2018 | 12:25 AM
CapnRon's Avatar
Ok... bewildered for sure. Fan control module arrived today. No change.
Fuse tested good. Fan tested good. Confirmed working module did not provide a fix.
Checked all other fuses in the box. All good... no fan.
I gotta figure this thing out... any clues...?
Old Jul 8, 2018 | 04:23 PM
Jon2211's Avatar
How did you test the fuse? Did you actually swap the fuses over or test it?
I did the same. I took the fuse box apart, removed all the fuses, cleaned the contacts replaced the fan fuse with a new one, started the engine with the ac on full and the fan started straight away.
Old Jul 8, 2018 | 04:43 PM
Is the "Low Coolant" light on? I mean, start car, do you see this on the left side of the dash?
Old Jul 10, 2018 | 05:02 PM
The AC control on the console sometimes fails and causes problems. If the fan speed switch is turned all the way to the left, anti clockwise, the AC does not switch on so I guess if this control has failed then the AC and the engine fan could possibly not work. There is a thread on how to make the contacts on this module connect properly. It is a lot of work but might be worth it.
Does the fan work on a hot engine? Maybe I missed the answer to that question as it is an obvious one for someone to ask.
Valk
Jul 12, 2021 09:49 PM
johnnycross413
Mar 4, 2016 04:49 AM
2005 Ragtop
Oct 3, 2015 03:01 PM
Oct 1, 2015 01:42 AM
Billy22Bob
Sep 26, 2015 10:16 PM
