Let's discuss the key fob transponder chip(s)
As you probably know, the cost of getting a new key fob for Crossfires has skyrocketed. Further we are advised that soon they will not be available at all. As you probably also know, there is a little "transponder chip" in the key fob that must be matched to your SKREEM module (or immobilizer) in your car for it to start and run properly. Accordingly, you cannot just simply purchase a new or used key fob from E-Bay (or where ever) install your key blade or a newly cut key blade and have it work to start / run your car. You must also have the correct transponder chip to match your car's electronic anti theft system.
I recently bought several brand new Crossfire key fobs with uncut key blades. These all have a transponder chip inside. Looking at a few of those transponder chips I see that each has three lines of information printed on it.
The first line is: PCF 7930AS This is the same on all of the transponder chips I examined . . .
The second line on the chips is different on the chips I have examined. Examples are: VAUX30 07 and VAUX30 09
The third line on the chips is also different on the chips I have examined. Examples arenD4182 and DnD5132
Which information identifies that particular transponder chip? How many different transponder chips might there be??
If anyone has information / knowledge to add here about these transponder chips, please share your expertise here . . .
on
Re: Let's discuss the key fob transponder chip(s)
RED DOG - I do not have a direct answer to your questions, but I recently got involved with the key fob/SKREEM posts on this forum. Bargegeek gave me the name and email address for a company in Canada who does a lot of key work and SKREEM programming. I know that you said your main concern is the key and I thought this company may be able to help you. The company name and email address is the same. Just email Autokeypro.ca and/or look up Autokeypro on the internet.
They were very helpful and quick to reply to my email questions about the SKREEM unit. In hearing from them, I think their main expertise is in key and key fob work.
I hope this will help you and help to resolve your concerns. If you will, let me know how this works for you as I may have the same problem someday.
Good luck,
Jim Holian
Good luck,
Jim Holian
I am surprised that any new key that you have cut with a new chip, can't be easily programmed to match the Skreem. Maybe there is and the information has not been released.
Some GMs have a procedure to match a new key to the security system on the car.
James
James
Good luck,
Jim Holian
Good luck,
Jim Holian
Thank you for bringing this community to my attention and it was great talking to you over email. Looking forward to contributing to this forum and learning from it.
Hi RED DOG,
To answer your questions, there are at least 40 different kinds of transponder chips, each make and model and year range has specific Immobilizer systems that require specific transponder chips. Don't ask me to list them as there are many but a google search will give you a good idea.
As for how to identify the different chips, the writings on the ceramic transponder can identify it. Other cases where there are no writings, you require a transponder reader and knowledge to know the type of chips they are.
As for creating new keys via SKREEM module, advanced expertise is required to be able to do that job and we have that in house if ever needed. Cloning/Repairing Computer Modules is also part of our in house services. This is open to the crossfire community.
Cheers
Hi Jim,
Hi RED DOG,
Cheers
Hi RED DOG,
Cheers
Excellent information. That's exactly the type of information and expertise I was hoping to be able to find! So, is it possible to buy a second matching transponder chip if we can provide you with the imaging that's on a correct transponder chip? Do you have the ability to re-program a non-matching transponder chip or can that even be done? Thanks again for sharing your expertise . . .
Hi
For anyone that wants to experiment with making/duplicating their Crossfire keys. The correct blank chip to use is a PCF7935AA
Like these ones on eBay: https://www.ebay.com.au/itm/10PCS-PC...s/172143666760
You can program them with this: https://www.ebay.com.au/itm/OBD2-Min...w0E9:rk:1:pf:0
Have fun!
Have fun!
I thought there were three elements to a crossfire key fob: Physical key, remote lock/unlock circuit board with battery, and a RFID transponder to make the SKREEM happy.
Had a fob with a broken key & worn buttons, just bought one of the $7 cases with uncut key from eBay, had the key cut to match the valet key and did a mix and match. Now have a fully operational fob with new buttons.
on
I think the SKREEM modules can be duplicated as well, I'm going to try and copy one and I'll let you know how it goes. However, as others have said, it would probably be much easier just to repair them as I'm sure its only a simple component failure.
on
Hi
Have fun!
Have fun!
It would be fun if it worked, but even if it did, our fundamental issue remains: The SKREEM.
First you copy it and then you improve it so much that the world beats a path to your door to buy it.
Kaizen (改善) is the Japanese word for "improvement". In business, kaizen refers to activities that continuously improve all functions and involve all employees from the CEO to the assembly line workers.
on
IT is bad enough that Kenwood is now building stuff in Singapore, Japan and other countries in an attempt to thwart China's efforts. If you google "Motorola versus Hytera", you can see how far this has gone.
So far, I do not see what you are describing. The cultural and economic differences between Japan and China are, in my view, huge. Perhaps someday, but not now1
on
