18s on the rear?
Old Nov 11, 2006 | 01:00 PM
dahntahn's Avatar
Question 18s on the rear?
Hey,
Has anyone put 18s on their rear axle? The dealer says it can't be done with the aftermarket rims I have. The owner's manual says you can put them on the rear in the winter.
My mechanic wants to cut the studs because he says they are too long and I also would need different bolts.
Anybody put 18's on the rear.
I need some input.
Old Nov 11, 2006 | 01:05 PM
andrew's Avatar
-C-I-C-C-I Associate Member
Default Re: 18s on the rear?
some members are indeed using 18's on the rear... this can be done.
if your existing lugbolts are too long they will rub/interfere with e-brake mechanism when the car is moving. if this is the case... the bolts may need to be shortened.
Old Nov 14, 2006 | 11:20 PM
HDDP's Avatar
Are you talking about 18" rims ? If so, you can definitely put them on... I run 18x10.5" rear rims with a 10mm spacer.
Old Nov 15, 2006 | 12:58 PM
dynamicS's Avatar
what's the widest rim you can put on the front of the car?
Old Nov 15, 2006 | 01:30 PM
HDDP's Avatar
depends on the diameter and tire size.
Old Nov 15, 2006 | 04:18 PM
dynamicS's Avatar
Same diameter as stock. Is it possible to go as wide as the rear?
Old Nov 15, 2006 | 05:04 PM
HDDP's Avatar
The problem on the front is the upper A frame bolt. You'll have to test the clearance with the tire mounted. You can put spacers on the front, but I do not recommend it if you are going to do any HARD driving (track stuff).
Old Jan 2, 2007 | 06:44 PM
gentlemanjim's Avatar
I think 18's all the way around would look stellar. Staggered wheel width is very common practice with BMW, Porsche, MB.
usprb1976
Apr 4, 2024 04:57 PM
blackpepper
Dec 18, 2021 06:17 PM
Jonacross
20
Jul 17, 2017 11:19 PM
2005 Ragtop
Oct 3, 2015 03:01 PM
jaesa
Sep 7, 2015 01:50 PM
