Light Weight Battery
Old Jul 3, 2007 | 09:28 AM
spensley's Avatar
Default Light Weight Battery
First off - I wasn't 100% sure where to put this thread - so here it is... ta da!!!
If some of you are REALLY hell bent on reducing weight - and I mean REALLY hell bent, check out this website...
http://www.tekbattery.com/
Old Jul 3, 2007 | 10:02 AM
polywave's Avatar
Default Re: Light Weight Battery
If I needed to crank my engine THAT long I think I'd best take the extra $700 I would spend on one of these batteries and spend it on the problem
I compared several of these batteries to the sealed lead acid batteries on the Interstate website:
For the same A-H
assuming the sealed lead acid batteries crank well (they always have)
these batteries are the same size.
Their advantage is they are half the weight of the sealed lead acid batteries Interstate offers.
Old Jul 3, 2007 | 12:34 PM
Maxwell's Avatar
Uh, Lithium ion battery would be very dangerous to keep under your hood. They are extremely flammable when damaged, so if you get into an accident this is not something you want near a fuel rail and fuel lines.
Old Jul 3, 2007 | 04:48 PM
spensley's Avatar
They can make them a lot smaller.
They can also make them the same size just by filling the existing/old housing with foam.
Relocate the battery to the trunk - that problem is solved - now we just need it cheaper.
Old Jul 3, 2007 | 05:52 PM
Maxwell's Avatar
Not really because the fuel tank is in the trunk, but I'm sure you can figure something out, that is if you really want a lithium starter battery. Next your going to have to engineer a special battery regulator to charge the battery, big $$$, and you might also have to redesign the alternator, more $$$.
God forbid you accidentally overcharge the lithium battery, because they burn at 2,500 - 3,000 deg F.
Old Jul 4, 2007 | 01:54 PM
Maxwell's Avatar
Do you really want this in your trunk?
http://www.youtube.com/watch?v=SQ0SNESIkWk
http://www.youtube.com/watch?v=lCFUGDcSuLw
Old Jul 4, 2007 | 05:42 PM
spensley's Avatar
It was a purely sarcastic message for people who wanted to reduce/redistribute weight.
Relax!!!
Old Jul 4, 2007 | 06:16 PM
HDDP's Avatar
We use lithium batteries for the Panavision cameras on feature films... We have to ship them "SPECIAL" when flying out of the country...
I've seen these things go KABOOM before...
On a serious note... You can use a dry cell battery to reduce weight, but they're not as robust... http://www.odysseybatteries.com/applications/auto.htm This is what I have mine... located in the rear pass area...
Old Jul 4, 2007 | 06:30 PM
Maxwell's Avatar
Relax!!!
I'm not uptight just thought you where seriously going for this light weight battery.
pioneer4x4
Jul 1, 2021 10:56 AM
Kodebuster
Nov 5, 2020 04:06 PM
pioneer4x4
Mar 25, 2019 10:35 AM
northwest_crossfire
May 30, 2016 05:19 PM
RiderJC
Aug 4, 2015 10:25 AM
