Crankshaft Position Sensor
Old Mar 19, 2010 | 09:47 PM
  #81 (permalink)
XF redo's Avatar
Default Re: Crankshaft Position Sensor
Well, it's the second day after our 1st "check engine" light came on (P0335 CPS). I reset the alarm and many starts later, no alarm, knocking on my wooden head for luck here. Maybe just a fluke, maybe fate, there were a lot of Indiana state troopers out yesterday so I baby'd her home.
Old Mar 20, 2010 | 11:33 AM
  #82 (permalink)
MikeR's Avatar
XF redo,
I would suggest that you get a CPS and have it on hand. Usually, once the error starts popping, it will just get worse, until it fails hard. You dont want to be stuck out on the road when you cant start your car.
Old Mar 20, 2010 | 11:36 AM
  #83 (permalink)
bmorgan's Avatar
I only had the P0335 come on one time, but for $38, I replaced it and kept the original as a backup in case of need.
Old Mar 20, 2010 | 11:37 AM
  #84 (permalink)
Originally Posted by MikeR
XF redo,
Mike is right on the money on this one. This is a warning, not a fluke...this car is just too smart for its own good....I think my sensors I have on hand, not had to use them yet, were $47 bucks, and a "how to" on here for the install....good luck....if not, I hope you subscribe to "AAA".....
Old Apr 8, 2010 | 07:14 AM
  #85 (permalink)
Blast Chamber's Avatar
Default Re: Crank Position Sensor
Bosch Crankshaft Position Sensor < click
Currently available for just $40.81
Order one now just to have a spare one on hand.
It's currently on sale for $39.11!
I just ordered my spare as well. Thanks for the link!
Old Apr 11, 2010 | 07:15 PM
  #86 (permalink)
danhaman's Avatar
My car just popped a P0341, crankshaft position sensor' also, I believe. I was going to take it to the dealership on Monday, but yesterday the CEL was out. Does this sound like the same "it's just a matter of time" situation?
Thanks,
dh
Old Apr 11, 2010 | 09:32 PM
  #87 (permalink)
MikeR's Avatar
P0341 is the CAMshaft position sensor.... causes same symptoms....it is mounted on the front of the motor and much easier to get to...
Old Apr 11, 2010 | 10:07 PM
  #88 (permalink)
danhaman's Avatar
That's great news! Given the circumstances should I expect it to fail at some point in the future? There were zero symptoms other than the CEL...which did not light back up when started the next day. Is it worth taking in now or should I wait until something comes of it?
Thanks!
dh
Old Apr 15, 2010 | 08:39 PM
  #89 (permalink)
danhaman's Avatar
Dealership quoted $470 to replace the cam shaft position sensor. Sounded steep as the part retails for $160 or so.
Glad it's under warranty.
Dh
Old Apr 16, 2010 | 04:16 AM
  #90 (permalink)
OzCrossfire's Avatar
Wow... if our exchange rate was what it was 12 months ago I could have flown over and replaced it for you for that price.
Old Apr 16, 2010 | 05:11 PM
  #91 (permalink)
dejohnny's Avatar
Originally Posted by DanielNTX
Well my car was randomly stalling on the streets and was pulling code P0335 which means "Crankshaft Position Sensor Circuit Error". I had problems starting the car after it stalled and I could restart it after a few minutes of cooling down. Apparently the Crankshaft Position Sensor is affected by heat when it fails. I did a lot of research on MBWorld.org and found many threads on the subject: Engine Quiting - MBWorld.org Forums
I pulled it from the service manual already. It just says remove connector but it doesn't say how. There's actually a small clip that attaches to the part. You have to push the rear end down and pull it off. Don't pull on the wire. Then after you have to take a star socket and remove the retaining bolt.
The Mercedes Part # for the Crankshaft Position Sensor is 003 153 27 28. Unfortunately, no local autoparts store in Austin carried it. The average price for an aftermarket part is $80-90. I went to the Mercedes Dealership to get it and the part has been updated to part 003 153 28 28 and it cost $153.90 for the original Mercedes part.
I would say overall that it's easier than replacing a spark plug, but it's in a tight space and you can't really see or maneuver too much. If you're good with mechanics and you have the right tools it should take about 20 minutes to replace, not the 1.25 hours of labor quoted to me.
I've included a bunch of pictures so if you guys ever run into the problem.
Picture #1: Bolt, Star Socket, New part on the left, Old part on the right
Picture #2: Socket, Top of Screw, New on left, Old on right
Picture #3: Rear of engine where sensor is in the center of picture
Picture #4: Picture of where the sensor goes and the bolt hole
Picture #5: Picture of cable
Picture #6: Picture of sensor installed and cable attached
Picture #7: OBD II - no errors
I think this one should be a sticky! I've had this problem before and it's very embarrassing.
Old Apr 17, 2010 | 09:35 AM
  #92 (permalink)
I just ordered a spare for my parts bin also. Thanks for the link, Gary.
Old May 10, 2010 | 10:47 PM
  #93 (permalink)
tmtait's Avatar
Nice shootin' Tex!!!
The photos and the information is very much appreciated. Especially the photos. A picture makes all the difference. Thank you more than I can say.
Grateful for the visual <3
Warmest regards,
Tmtait
Old May 11, 2010 | 01:43 PM
  #94 (permalink)
Veloce's Avatar
Great price!
I ordered one for $39.11, too.
I also ordered a couple of other things to bring the total up another $11.00 and got FREE shipping (a savings of $10.39 and only paid 61 cents for the spray wax!)
One note on the photos of the part. I ordered and received the Bosch 0 261 210 170 which looks identical to the part you've labeled as your original. In other words, you list the part on the left as the new and the part on the right as the old one; mine looks exactly like the part on the right
Old Jun 12, 2010 | 10:19 PM
  #95 (permalink)
lioness0728's Avatar
Unhappy Re: Crankshaft Position Sensor
Hello fellow Crossfire lovers. New to this forum and hoping someone can assist. Just dropped off my 2004 at the local dealership and what I got was a qoute for $1030.00 + for a Crank Sensor and also an "Engine Relay Bank". In just a few minutes on the net I learned all about the Sensor, but an "Engine Relay Bank"? Can anyone shed some light on this for me?
Old Jun 12, 2010 | 11:10 PM
  #96 (permalink)
texas t's Avatar
Talking Re: Crankshaft Position Sensor
===== Here you go fix it yourself are get a new one for about 150$ https://www.crossfireforum.org/forum/crossfire-srt6/38338-relay-control-module-engine-wont-start-repair-offer.html
Old Aug 10, 2010 | 09:27 PM
  #97 (permalink)
SparkieSRT6's Avatar
SSB SRT6 405hp/401Tq
I did and it came today via UPS
Can anyone please confirm that this C.P.S. from AutohausAZ will work on both the NA Limited and the SRT6.
Thanks in advance.
Old Aug 10, 2010 | 09:41 PM
  #98 (permalink)
bluecoupe's Avatar
Confirmed, same cps for NA and S/C engines
  #99 (permalink)
Sorry, here is Gary's post with the link. Can anyone please confirm that this part is good for both the SRT6 amd the NA Limited.
Thanks in advance.
Old Aug 10, 2010 | 09:44 PM
  #100 (permalink)
Steve, Your awesome thanks.
Sending you pm.
