Change thermostat?
Old Jan 24, 2008 | 05:42 PM
sonoronos's Avatar
Default Re: Change thermostat?
Originally Posted by erikson
Lower engine temp tricks the CPU (computer) in thinking that the engine is not wormed up yet. The CPU (computer) then adds more gass than usual. Making the engine run rucher. More gass means more horsepower. It's cheeper than adding larger injectors.
I hate to be the forum naysayer, but everything you said is correct except for the "more gass means more horsepower" part.
This is only true if there is more air in the cylinders.
Old Jan 24, 2008 | 06:36 PM
TVT_DESIGN
Guest
Posts: n/a
It actually helps to reduce the retarded timing, that's where most of the power comes from.
We'll be trying to document HP gains of all our products soon. We're meeting with our Dyno guy next Friday to arrange a day we can rent the facility for some N/A and SRT6 testing.
Old Jan 24, 2008 | 07:50 PM
Jeep2Xfire's Avatar
I thought more air is more power. (Motor is a big air pump) Suck, Squeeze, Bang, Blow!!!
Old Jan 27, 2008 | 05:10 PM
H.K. Phooey's Avatar
Does anyone have a part # for the lower themo thermostat?
Old Jan 27, 2008 | 05:53 PM
HDDP's Avatar
Lower thermo? I'm out of town right now and can't check my tech manuals, but the engine coolant system only has 1 thermo... There may be another that is associated with the HVAC system, is that what you are referring to ?
Old Jan 27, 2008 | 06:12 PM
I meant lower temp thermostat
Old Jan 27, 2008 | 06:34 PM
HDDP's Avatar
I've spoken with many MB specialists and they tell me that nobody offers a higher flow, lower temp "flow opening" thermostat for this engine... So don't be surprised if you get some convoluted answer to your post...
If you want to free-flow your coolant, just remove the thermostat all together... No need to purchase something that is smoke and mirrors !
Old Jan 27, 2008 | 07:16 PM
TVT_DESIGN
Guest
Posts: n/a
Hello,
We sell an increased flow thermostat, check it out here: http://www.tvtdesign.com/inc/sdetail/99.
There are several members on this board that have already purchased this and are very happy. It will help keep the engine temp low and the power up.
Thanks,
Anthony
TVT Design
Old Jan 27, 2008 | 08:13 PM
HDDP's Avatar
SELF EDITED
Sorry guys, I keep forgetting we're talking about street vehicles... Thanks Brian... My mind is so focussed on race engines that sometimes I forget that what's good for the track, isn't so good for everyday driving...
Old Jan 27, 2008 | 08:40 PM
BrianBrave's Avatar
<--- Huge Horsepower
I found this thread over at mbworld - interesting read
http://www.mbworld.org/forums/showthread.php?t=148316
Valk
Jun 22, 2025 09:15 PM
UNDER PSI
Nov 1, 2015 09:39 PM
jimf
Oct 10, 2015 10:22 AM
o55ie18
Oct 5, 2015 05:50 PM
nataliefs
Oct 5, 2015 01:03 PM
