74mm Throttle Body Upgrade
Old Sep 11, 2012 | 12:08 AM
  #221 (permalink)
Kickerinthehead's Avatar
Default
Originally Posted by alaxfire
Well, it IS possible if the rumor I have heard is indeed true :
Wikipedia says :
SL 320 with a M112 3.2 L 18-valve SOHC V6 (224 PS (165 kW; 221 hp) at 5600 rpm
( that's 6 more hp than the Crossfire's 215, I believe the SL320 had the 74mm TB )
But I have also heard that the true HP of a stock N/A Crossfire is around 240.
I have never seen any facts to back that up, however if true, then my mods might well place it in the 260-270 HP range.
I'm just too frugal ( mrmiata's word for cheap ) to drive 100 miles one way to find a dyno and know for sure.
True hp? As in the advertised power for the crossfire is just plain wrong?
Old Sep 11, 2012 | 07:05 AM
  #222 (permalink)
Default Re: 74mm Throttle Body Upgrade
The same rumor has it that Daimler made Chrysler advertise lower HP so as to not compete in sales with the MB 2 seaters of the time.
Like I said, all rumor and speculation.
Old Sep 11, 2012 | 10:41 AM
  #223 (permalink)
dtinker's Avatar
My LTD XF Roadster is getting 211.4 RWHP with the mods listed in my signiture. Everyone tells me there is about 20% power train HP loss, so that would make crank HP somewhere around 264HP. The car run great, but not SRT6 performance. I would love to do a Supercharger or Turbo, but they are so expensive. I have thought about adding a NOS kit to it, but don't want to kill the engine by over doing it. I think it somewhere between 243 and 254 crank HP.
Old Sep 11, 2012 | 12:36 PM
  #224 (permalink)
Point blank, we heard from the lead engineer on the crossfire project in Michigan last year that the SRT rating of 330 HP versus the SLK32's 349HP rating was total BS as well. They were the same motor, and same HP, but MB would not let them advertise a competing car with the same HP...
I have never heard this of the NA and SLK320, as both were rated at 215HP. If the motor put out more than that, I think MB would have capitalized in their sales literature for the 320...
Old Sep 11, 2012 | 02:00 PM
  #225 (permalink)
Wikipedia says the SL320 has 221 HP :
Old Sep 11, 2012 | 02:12 PM
  #226 (permalink)
Is yours an auto or manual? I've always heard that an auto tranny will rob more horsepower than a manual.
Old Sep 11, 2012 | 03:12 PM
  #227 (permalink)
Wikipedia is also user driven, and user supplied info...
Here are a few more reliable sources:
2004 Mercedes-Benz SLK-Class SLK320 Convertible 3.2L V6 6-speed Manual Features and Specs
2004 Mercedes-Benz SLK-Class Summary
Old Sep 11, 2012 | 03:38 PM
  #228 (permalink)
OK - I stand corrected. ( stupid me for believing WikiPedia .... )
Old Sep 12, 2012 | 08:42 AM
  #229 (permalink)
LOL until I looked it up, I could not remember if it was 230 or 215 on the SLK
Old Sep 19, 2012 | 10:07 AM
  #230 (permalink)
simkard's Avatar
Hi,
I just bought a TB of 74mm from eBay which is here : eBay | Mercedes CLS W219 W 219 Drosselklappe 0280750017 A 1131410125 Motor M272
I would like to know, if i can keep the actual MAF case or do i have to replace it with a 74mm one because its diameter is like the old TB (68mm) ?
By the way, same question for the "elbow" and the "O'Ring".
Can you please give me the REFERENCES of the parts ?
Thanks !
Old Sep 19, 2012 | 10:17 AM
  #231 (permalink)
Originally Posted by simkard
Hi,
Thanks !
https://www.crossfireforum.org/forum...ttle-body.html
Using the old elbow and the O-Ring if it is OK, but it is best to get a new one.
Old Sep 20, 2012 | 04:27 AM
  #232 (permalink)
simkard's Avatar
I already looked @ this post.
What i would like to know (i could verify it on my car but as for now it is not close to me ...), is the diameters of the actual MAF housing and the elbow.
As the diameter of the throttle body is actually 68mm, i must think that the MAF housing and the elbow are the same ... so basically, changing just the throttle body would not give some gain.
Is it possible to find just the MAF housing and the elbow for cheap ?
By the way, does the O'Ring diameter is like these 2 parts : 68mm and should be changed to 74mm too ?
Thanks !
Old Sep 20, 2012 | 09:44 AM
  #233 (permalink)
dtinker's Avatar
The O.D. is the same on all these parts, it's the I.D. that is different. If I remember correctly the "O" ring for the TBis the same for either the 68mm or 74mm TB., the elbow is the same for either. The MAF and TB are 68mm and 74mm for both. I changed the MAF and the TB and took the baffles out of the elbow and the screens. I left the screen in the engine cover. I swapped the flow sensor in the MAF ( removed the sensor in the 74mm and replaced with the 68mm sensor). Got a few more RWHP, but improved sound and response.
Old Sep 20, 2012 | 02:12 PM
  #234 (permalink)
Thanks !
The elbow is OK, it fits the OD of both size throttle bodies as they are the same size outside except that the inside diameter of the 74mm throttle body is 74mm and the inside diameter of the 68mm throttle body is .......68mm. The O-ring is the same for both throttle bodies. The answers are all in that post.
Old Sep 21, 2012 | 04:18 AM
  #235 (permalink)
simkard's Avatar
Hi, thanks for your answers, but, after reading the whole post, i just couldn't find the 74mm MAF housing MB ref.
Could you please tell me which is the good ref for this part, i will try and look over the net to buy one for cheap.
Basically, i understood that the "Intake Manifold", "Elbow", "O'Ring" are the same diameters which are compatible with the "74mm Throttle Body".
But it seems that there is the MAF housing which is not good at all.
Hope you can help me to find the good way of doing the right mod with the right parts.
Thanks !
Old Sep 21, 2012 | 09:56 AM
  #236 (permalink)
Could you please tell me which is the good ref for this part, i will try and look over the net to buy one for cheap.https://www.crossfireforum.org/forum...tml#post578585
Thanks !
It is in this thread as noted above, post #231.
Here it is again, 74mm was 3", so I changed it.
Old Sep 21, 2012 | 11:21 AM
  #237 (permalink)
simkard's Avatar
Ok thanks and sorry for my mistakes. I apologize.
Here is what parts i ordered, with good and cheap prices :
USED --- 74mm Throttle Body - REF : A1131410125 (Mercedes Benz) // 0280750017 (Bosch)
ONLY 70€
BRAND NEW --- 74mm MAF housing + sensor - REF : 0280217810 (Bosch)
eBay | New Auto Parts Assembly Air Flow Sensor Meter 0280217810 For 98-09 Mercedes
ONLY 15€
BRAND NEW --- O'Ring - REF : A3059970345 (Mercedes Benz)
MERCEDES BENZ PARTS STORE (on site)
ONLY 7.62€
Finaly, i will do this mod by myself and the cost of the parts are less than 100€ !
What a good deal !
Thanks everyone !
NEXT STEP : Removing the catalyst
Old Sep 26, 2012 | 03:55 AM
  #238 (permalink)
simkard's Avatar
Hi,
Me again ... I still haven't received my items, but, as i only ordered "Throttle Body 74mm" + "O'Ring" + "MAF housing (+sensor)", i would like to replace the elbow with something new.
Can someone please provide me the good REF of the part please ?
Thanks !
Old Oct 28, 2012 | 07:01 AM
  #239 (permalink)
falshami's Avatar
so i read this whole thread only to be a bit more confused... TVT was a company doing these mods but closed down right? were they lying? and can our car engines really put out 270 at the crank? especially after all these promised mods by tvt? how much ACTUAL hp did people get from this mod? and where can i get all the parts required for this? can someone post a link to these items?
Old Jun 28, 2022 | 09:35 AM
  #240 (permalink)
Jfrankc99's Avatar
My question is: will an 82mm or 85mm work on the crossfire engine in stead of going with the 74mm?
