74mm Throttle Body Upgrade
Old Jul 1, 2009 | 01:14 PM
  #141 (permalink)
04matthew's Avatar
Default Re: 74mm Throttle Body Upgrade
Ok Confused What Do I Have And Do I Need To Modify Anything On It? Sorry Bout The Caps, Broken
Old Jul 1, 2009 | 03:49 PM
  #142 (permalink)
TVT_DESIGN
Guest
Posts: n/a
Responded to over phone.
Old Jul 15, 2009 | 08:26 AM
  #143 (permalink)
stevieb's Avatar
Originally Posted by G3arh3ad
Mercedes Part # A1131410125
Bosch Part # 280750017
Thats the 74mm Throttle Body (though mine is not from TVT) I'm going to install in the next hour
Hi guys,
just recieved my Throttle body not fitted it yet but need to check some part numbers with you as im confused.
The part numbers on my unit are Mercedes part # A1121410125
Bosch Part # 280750019
whats the diference from mine to the one quoted by G3arh3ad above?
Old Jul 15, 2009 | 06:54 PM
  #144 (permalink)
MI1XFIRE's Avatar
Originally Posted by stevieb
Hi guys,
Yours is the stock 68 mm TB and his is the 74 mm
Old Jul 15, 2009 | 07:00 PM
  #145 (permalink)
JM, did you sell yours?
Old Jul 15, 2009 | 08:44 PM
  #146 (permalink)
MI1XFIRE's Avatar
I have one on my car and sold the other two I had purchased earlier to determine what was the best one to use.
Old Jul 15, 2009 | 09:49 PM
  #147 (permalink)
OK, I thought if still had it, I would buy it. Which one do you have on your car?
Old Jul 16, 2009 | 06:54 PM
  #148 (permalink)
MI1XFIRE's Avatar
I have this one installed on my car:
Mercedes part number A 113 141 01 25
Bosch part number 0 280 750 017
This is a direct replacement "Plug and Play". If you purchase a used one make sure that it has both of these numbers on the TB label. A lot of Ebay listing are erroneous if you just go by year and model.
Old Jul 16, 2009 | 09:55 PM
  #149 (permalink)
Thanks my friend.
Old Jul 16, 2009 | 10:15 PM
  #150 (permalink)
downwardspiral's Avatar
anybody know where to get one?
Old Jul 16, 2009 | 10:40 PM
  #151 (permalink)
This one is aftermarket. But is this the one?
http://cgi.ebay.com/ebaymotors/Merce...A1%7C72%3A1171
Old Jul 17, 2009 | 01:45 AM
  #152 (permalink)
oops. Erased my post.
Old Jul 20, 2009 | 02:19 PM
  #153 (permalink)
Anybody looking for a TB? I found a couple around $200 if anybody is interested.
Old Jul 20, 2009 | 03:59 PM
  #154 (permalink)
JimmySkullz's Avatar
I am let me know
Old Jul 20, 2009 | 07:13 PM
  #155 (permalink)
MI1XFIRE's Avatar
No that's not it...here is a pic of what to look for with the above listed part numbers
Old Jul 21, 2009 | 12:26 PM
  #156 (permalink)
Jerk Daniels's Avatar
I am definitely going to be aggressively looking for one of these 74mm throttle bodies come August - perhaps one of those will still be laying around....
and slightly off topic:
If I were to find a used SLK/CLK 320 airbox, would my current intake tubes match up? And if not, TVT, how much would you sell me your custom tubes for? (Something I'd eventually want to do even if the stock tubes will mount)
Old Jul 24, 2009 | 02:30 AM
  #157 (permalink)
G3arh3ad's Avatar
Originally Posted by Jerk Daniels
If I were to find a used SLK/CLK 320 airbox, would my current intake tubes match up?[...]
Just as a hint: What you want to look for is the CLK airbox - it has more volume after the filters, uses larger air filters&tubes and has more airflow. That is the one TVT is selling and for this airbox you may get the custom tubes from them.
The SLK airbox on the other hand is just for the looks and is pretty much as restrictive as our airbox. For this airbox the intake tubes of our cars can be reused (same diameter).
Old Jul 31, 2009 | 02:21 PM
  #158 (permalink)
If anybody wants one, I have 2 in my possesion. $210 shipped.
Old Jul 31, 2009 | 10:08 PM
  #159 (permalink)
Are they plug-and-play?
Old Aug 1, 2009 | 09:11 AM
  #160 (permalink)
Yes sir, same part # as the one on my car, 113 141 01 25.
