Throttle Body Modification
Old Dec 4, 2009 | 04:57 PM
rcompart's Avatar
Default Re: Throttle Body Modification
Woody, I need to give you a call about something. You going to be around this weekend?
Old Dec 4, 2009 | 05:32 PM
waldig's Avatar
Mid day Sat or Sunday Ill be doing garage things and painting inside of house, sure.
WEEKEND AGAIN, YIPPIE !
woody
Old Dec 4, 2009 | 07:58 PM
Originally Posted by Beaner
180 ... you can use mine as a demo if you want ... just be gentle. I was planning on going bigger than stock in the spring anyways.
Thanks a lot but if I do it, I'll risk my own. That way if I screw up I will not have to admit it to anyone.
I wonder how much I can remove from the bore, can I get to 74 mm or not, it looks a little too thin to remove 3 mm per side.
Old Dec 4, 2009 | 08:08 PM
you guys are braver than me...I use to do that to the carbs on the bikes I raced, not so sure I want to risk it on the car....good luck, maybe you can convince me...lol
Old Dec 4, 2009 | 09:26 PM
Bulldogger's Avatar
If your brave enough to stick the TB in a box with a check for $163, $150 for bore $12 return postage, then your done. Really not scarey at all
tighed1's Avatar
Well it's only gonna be in the 50's tomorrow so I might try to get in and do some port matching on the coupe in preparation for the West Coast Shootout.
Gotta try everything to get into the dang 11's!
Watch out Cruzin'. I'm coming for ya!
Old Dec 6, 2009 | 11:51 PM
BlueStorm's Avatar
a smarter idea would be to start with the big v8 TB, bore that out, might need to destroy one to find max ID for bore. and then change the closed throttle valve angle for about 3-5 degrees more agressive, that should help remove any throttle lag.
let me know if you need help on how to change the angle, you will need to buy some decent ID calipers.
Old Dec 6, 2009 | 11:55 PM
tighed1's Avatar
But that would be like "spraying"!
I did get to the port matching. There was a lot of overlap that got taken out. It has to help.
Old Dec 7, 2009 | 01:37 AM
Bulldogger's Avatar
It doesn't make that much of a difference on FI, better results with NA cars.
Old Dec 7, 2009 | 03:29 PM
MikeR's Avatar
Maybe not much...but every little bit helps... and it only costs time....not losts of $$$$...
Old Dec 8, 2009 | 07:07 AM
Infinite's Avatar
and another thing, since im in the middle of swapping guts to my 74.
the crap that mercedes seals the plastic end housing in is like concrete.
not to mention getting that stupid rubber amg thing off the end. ugh
im dreading actually swapping everything and closing it back up.
syfi
Mar 28, 2026 04:14 PM
cjw
Oct 26, 2015 10:26 PM
2005 Ragtop
Oct 3, 2015 03:01 PM
cjw
Sep 27, 2015 10:22 AM
atdavis2
Sep 21, 2015 01:25 PM
