Won't Start
Old Apr 27, 2010 | 10:44 PM
KROSSFIRE1988's Avatar
Default Won't Start
Well I Have An 04 Crossfire And It Wnt Start! The Car Would Click When I Tried To Start Her. So Figured Hey Its The Starter So I Replaced It. Guess What Still Wont Start.... Doin The Same Thing Get It To Click But No Start! Any Advice
Old Apr 27, 2010 | 10:48 PM
Infinite's Avatar
Default Re: Wont Start
Did it ever occur to you to charge the battery?
If you go to start the car and all you get is the rapid relay clicking sound its simply a weak battery.
Old Apr 27, 2010 | 10:51 PM
Well About 2 Weeks Ago The Alternator Went Replaced It And The Battery! So Im Confused We Got It To Start With A Good Ole Push Down The Hill And Dump The Clutch...
Old Apr 27, 2010 | 10:55 PM
Good battery connections? What is the voltage of the battery? What is the voltage when you attempt to start it? What is the voltage at the battery when the engine is running?
James
Old Apr 27, 2010 | 10:59 PM
Infinite's Avatar
its electrical, nothing to do with the starter
The battery could just be bad.. bad cell or something. Or the alternator wasnt installed properly.
Old Apr 27, 2010 | 11:05 PM
Well I Dnt Think It Is The Batt Or Alternator Cause It Wnt Even Start With Jumper Cables?
Old Apr 27, 2010 | 11:11 PM
Infinite's Avatar
unhook the leads from the battery and connect the jumper cables to the battery leads and see what happens. Remove your battery from the situation.
batteries can be so dead that they cant be jumped
Old Apr 27, 2010 | 11:15 PM
Exactly What I Tried Put Another Batt In Then Tried It Directly To The Leads. Nothin! Will Pushstart Fine Keep Parkin On A Hill Till I Can Figure It Out. But Im Clueless.
Old Apr 27, 2010 | 11:19 PM
Infinite's Avatar
everything on the starter installed correctly?
Old Apr 27, 2010 | 11:21 PM
Ya Its All Right! Had My Mechanic Do It. And Even Hes Stumped... Through Out Maybe A Neutral Position Sensor? But Dnt Know?
Old Apr 27, 2010 | 11:27 PM
Infinite's Avatar
the neutral position sensor shouldnt matter, you can crank the car with it in any gear as long as the clutch is in.
If the clutch interlock switch on the clutch pedal went bad, it wouldnt even attempt to turn over.
Double check that the connection on the alt are secure. even the slightest loose connection can cause issues.
Old Apr 27, 2010 | 11:37 PM
Well Checked All The Conn On Batt Alt Starter All Secure And Correct! When I Attempt To Start Still Clicks Once And I Can Hear The Fuel Pump Turn On But No Engine Turn!!!
Old Apr 28, 2010 | 12:26 AM
I Have No Idea Whats Wrong With A Push Start It Drives Fine Doesnt Die Or Cut Out No Over Heating Warning Light Nothing Just Wnt Start!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old Apr 28, 2010 | 12:32 AM
JHM2K's Avatar
No Crank - Relay Control Module
Crank no Fire - Crank Position Sensor
Old Apr 28, 2010 | 11:05 AM
MikeR's Avatar
Default Re: Won't Start
John, you sound like DJ....
Old Apr 28, 2010 | 12:02 PM
If It Were Either The Crank Sensor Or Relay Wouldnt Tthe Car Have Issues Running? She Drives Fine And Can Leave Her On For Hours, Just Wont Start
Old Apr 28, 2010 | 12:12 PM
MikeR's Avatar
No.... once started it would run fine.... though I think some may have reported random dieing....
Check your RCM solder joints first..... based on your description it dosent sound like the CPS...
Old Apr 28, 2010 | 12:22 PM
JHM2K's Avatar
Hahah I actually quoted him directly...
Old Apr 28, 2010 | 12:32 PM
This is not the CPS, sounds like it MIGHT be solder joint fractures on the Relay Control Module circuit board.
Pull the RCM as described in "How to relay control fix" and take a look at it. THEN, get back to us!
Old Apr 28, 2010 | 12:40 PM
Well Disassembled The Rcm And The Solder Looks Fine But Im No Electrician. The Only Thing I Notice Is The Barbs Do Extend Past The Solder.
