Effect of Sealant on Tire Pressure Sensor...
Old Mar 8, 2004 | 09:50 AM
Rob M's Avatar
Default Effect of Sealant on Tire Pressure Sensor...
Since I had used my entire bottle of sealant in a failed attempt to patch a tire, I was concerned after reading a couple posts on this site regarding possible damage to the pressure sensor in the affected wheel. Yesterday, I conducted a simple experiment. I lowered the pressure in the tire, which was plugged two weeks and 1000 miles ago, and still contains much of the sealant inside (what didn't shoot out of the hole in the tire). The dash sensor illuminated. I then used the little compressor that comes with the car to inflate the tire back to 34 psi. The low pressure light on the dash went off. Conclusion: the sealant supplied with the car should not effect the ability of a tire to sense pressures as designed.
rampntlion
21
Feb 11, 2019 08:18 AM
stelrz1
Sep 21, 2015 11:18 AM
waldig
Sep 17, 2015 10:35 AM
lazorouss
Sep 11, 2015 09:16 AM
RiderJC
Sep 7, 2015 11:19 PM
