Starting Issue
Old Mar 11, 2012 | 09:04 PM
poolboy's Avatar
Default Starting Issue
I just purchased a 2005 Srt 6 Roadster. Drove it home 600 miles. It has been driven every day since (last 4 days) This morning it started right up. After a short trip I got back in and would not turn over. All of the electronics are working. I hooked up a battery charger/starting unit to the battery and it started right up.
After driving around awhile I went home, same issue will not start unless hooked up to battery charger/starting unit. I figured bad battery and bought a new battery...Installed the new battery same issue, will not start unless hooked up to a charge/starting unit.
I saw the discussion about the solder joints on the RCM. Why would it start only when hooked up to a charging/starter unit even with a new battery.
Any advice?
Old Mar 11, 2012 | 09:11 PM
SparkieSRT6's Avatar
SSB SRT6 405hp/401Tq
Default Re: Starting Issue
Could possibly be the RCM but I'd start by going over and cleaning up all the main ground connections. Start at the battery terminals and look for all ground straps going to the block and body in the engine compartment.
Old Mar 11, 2012 | 09:44 PM
poolboy's Avatar
Thank you for your reply.
I did clean the terminal clamps, and ground screw from the battery to the body. no luck, any idea why it would start when hooked to a charger/starter unit? but not by the new battery alone?
I have not been able to get under the car to check the hot line/starter connection from the battery.
Old Mar 11, 2012 | 10:23 PM
Mrmiata's Avatar
Solenoid engaging but starter not turning kind of "won't turn over"..nothing at the key when turned to start? If the first I'd have to wonder if starter isn't going and needs the extra boost?
Old Mar 11, 2012 | 10:39 PM
poolboy's Avatar
When I turn the key I hear a relay or switch in the area of the RCM box/wiring harness area. Nothing at the starter. But as soon as I hook up the charging/starter unit it cranks and fires every time.
I've never heard or seen anything like this before. I didn't know if it was something unique to the crossifire or not.
The car only has 37,000 miles on it and you can eat off the engine compartment areas. I was hoping it as something simple!
Old Mar 11, 2012 | 10:48 PM
Mrmiata's Avatar
If you haven't looked over the RCM module yet.. make sure to check the contact faces on the relays.. That would be my course of action at this point.
Old Mar 13, 2012 | 04:28 PM
Smokin Red '06's Avatar
Default Wont Start First Time
Put the key in, try to start the Eng. i get nothing. Turn the key back off, turn the key back on & it starts right up with no problem, shut the Eng. off, try to start it again & it does the same thing. Any one with any ideas??
Old Mar 13, 2012 | 04:32 PM
waldig's Avatar
Talking Re: Starting Issue
If it starts every time with the charger, Id test the battery condition. Woody
Old Mar 13, 2012 | 06:54 PM
Default Re: Wont Start First Time
More info needed, not to many here can give an opinion without more input from you.
Old Mar 13, 2012 | 07:22 PM
Not to much to add, like i said i try to start it, it will crank then it dies so i turn the key off & then try it again & it starts right up. It will do this every time i get in & try to start it. It will not start on the first try.
Old Mar 13, 2012 | 07:28 PM
Could be the fuel filter drainback valve not sealing.
Try replacing the fuel filter.
Old Mar 13, 2012 | 08:13 PM
I don't think it's the filter. It won't drain back within 5 - 10 seconds. like i said. It's running & i shut it off & right away try to start it back up, & it will not srart the first try, Right away i turn the key off & try it again & it will start. I'm thinking it might be in the security system some where, like some one is trying to steal it. Thats why it won't start the first time. I don't know, got me stumped
Old Mar 14, 2012 | 07:19 PM
There are a lot more problems with cars that are run year round, have you noticed?
I know you know about most things, but does this sound like you?
https://www.crossfireforum.org/forum...tml#post609157
Old Mar 16, 2012 | 01:44 PM
dskul1's Avatar
Maybe because of my recent experience w/my SRT I always think of the leaks in the back of the car. I had a lot of trouble starting my car and it ended up because of water getting into the trunk area and shorting out the central locking module. It is also hooked up to the alarm system and if it is damaged, it may prevent the car from starting. I would check any XF for leaks in the rear hatch area anyway. From my short time on this forum, it seems like water leaks there are a common problem. Especially w/the SRT under the wing. It wouldn't take long to check out and like I said, I would check for water leaks on ANY XF regardless if it is a NA or not. Good luck!
Any advice?
KDW4Him
18
Sep 1, 2021 05:47 PM
PNA
Nov 12, 2020 04:44 PM
northwest_crossfire
May 30, 2016 05:19 PM
Bayukbros
Jul 17, 2015 11:21 AM
FIXRE
Jul 9, 2015 09:16 PM
