7500K lower fogs - bulbs installed
Originally Posted by bmerfan
Now matches my HIDs... 7500K PIAA extreams.. looks amazing.
Hi.
The bulbs are 55W.. they dont actually take more current.
For reference:
22 gauge = .92 amps
20 gauge = 1.5 amps
18 gauge = 2.3 amps
16 gauge = 3.7 amps
14 gauge = 5.9 amps
12 gauge = 9.3 amps
10 gauge = 15 amps
8 gauge = 24 amps
Ohm's Law tells you from above that at 12V the factory 55W bulb would need 14 gauge wire (4.58amps). The wires in the XF don't LOOK like 14 gauge, but insulation thickness can deceive the eye. If indeed they are 14 gauge, the maximum safe bulb wattage would be 70.8W (12V * 5.9A). So unless the XF has 12 gauge wiring to the lamps (doubtful), 70W would be the max safe bulb to use on 14 gauge wire.
Roty135
17
Oct 11, 2018 10:11 AM
Adrian_X
Nov 9, 2017 08:49 AM
[/url]
