Keyless Entry ... Lights Flashing
Old May 30, 2012 | 03:28 PM
04XFIREAtl's Avatar
Default Keyless Entry ... Lights Flashing
So when I lock my doors using my keyless entry, the doors lock but the lights flash on and off and won't stop. Anyone have any ideas?
Thanks
Old Jun 7, 2012 | 07:57 AM
blkXfire04's Avatar
Default Re: Keyless Entry ... Lights Flashing
Same thing happened to mine and there were alot of replies on here regarding this but noone seemed to have a clear cut answer, so I ended up pulling the fuse. Its a pain to manually lock the door but weighing the alarm to the manual locking its a choice I chose. Lots of ppl said to replaace the key fob batteries, that didnt work, some suggested changing the car battery but mine tested good so I wasnt about to replace that, some ppl said there may be water in the sensor area which was located under the carpet in the trunk which I tried and was pretty much causing more problems than fixing it. So, thats when I decided to pull the number 9 fuse. Look in your book. But that was my experience. Maybe this thread will come up with another solution. Good Luck I know how annoying it can be.
Old Jul 17, 2012 | 10:30 AM
04XFIREAtl's Avatar
Thanks man. I recently replaced the original Mopar battery (yea, it was still in an 04, pretty amazing) seems to have cleared up the problem.
Thanks for the response.
88stevie
19
Jan 21, 2026 01:46 PM
pioneer4x4
Jul 1, 2021 10:56 AM
pioneer4x4
Mar 25, 2019 10:35 AM
Hoppy
Dec 7, 2018 07:36 AM
northwest_crossfire
May 30, 2016 05:19 PM
