Driver side motor mount help
Old Jul 6, 2012 | 02:16 AM
ZJosh's Avatar
Default Driver side motor mount help
Resently I blew my motor mount macanice looked up and screw broke off the lower mount
Does anyone know what's the best way to replacing it I all ready got a new mount but macanice wants to take the compressor and other stuff to get some space in there but I said no
Any ways to fixing this easyer
Also adding a cable rope around the mount
Old Jul 6, 2012 | 05:52 AM
32krazy!'s Avatar
Default Re: Driver side motor mount help
motor mount has to be replaced from under the car. if he wants to remove the supercharger to get to the motor mount its a good sign you need another mechanic. you can remove the exhaust header for some room but the only easy way to get at it is to remove the engine. the mounts are installed from the factory before the engine goes in. its a very tight fit
Old Jul 6, 2012 | 07:49 AM
I think he is referring to the A/C compressor, not the supercharger, but in either case, find a new mechanic ........
Old Jul 6, 2012 | 02:20 PM
We may lose something in translation here, but the mount has to be replaced from below, not the top. Engine can be raised enough, to install the new mount from BELOW the car. NOT from the TOP. Good luck..l
Old Jul 6, 2012 | 03:41 PM
ZJosh's Avatar
I don't have a srt lol your wrong lol
Old Jul 6, 2012 | 03:43 PM
ZJosh's Avatar
That's what I'm sayin he already knows its from the bottom be he wants to remove a bunch of parts to get his hands in there
Old Jul 7, 2012 | 12:10 AM
WELL, he will have to move a few things....so I would let him do the work....
Old Jul 7, 2012 | 06:24 AM
32krazy!'s Avatar
having done the mounts i can tell you removing the a/c compressor wont help a bit. removing the exhaust manifold would help , but wait! you have to remove the motor mount to get to the manifold!! let him do it or not you should look into how much he really knows about these cars. btw you really should do both mounts at the same time. if the drivers side is gone the pass isnt far behind. and if he thinks the drivers side is tough he will want to pull the motor for the pass side!
BrenLW
Aug 5, 2015 04:53 AM
michaelcycle58
Jul 28, 2015 08:12 PM
waldig
Jul 20, 2015 08:10 AM
ZX2 Nick
Jul 15, 2015 08:49 PM
66L72M21
Jul 15, 2015 04:23 PM
