Replacing starter
Old Aug 30, 2012 | 07:20 PM
yorktown4's Avatar
Default Replacing starter
What steps do you go thru to get to the starter?
Old Aug 30, 2012 | 07:30 PM
robby363's Avatar
Default Re: Replacing starter
Here you go.
Old Aug 30, 2012 | 07:38 PM
yorktown4's Avatar
Thanks Robby
Old Aug 30, 2012 | 08:35 PM
Originally Posted by yorktown4
Thanks Robby
Pay EXTRA attention to the first step of removal (disconnect the NEGATIVE battery cable) and make sure nothing contacts the neg post of the battery!
Old Aug 30, 2012 | 09:18 PM
yorktown4's Avatar
understand
Old Aug 30, 2012 | 09:36 PM
Like what?
Inquiring minds want to know.
Old Aug 31, 2012 | 03:23 AM
Like what?
Your kidding, right?
I was never a fan of only removing a negative cable. I take the neg off first (swinging a wrench on the positive when the neg is connected is dangerous, you might accidentially drop/swing it too far to ground the terminal and it may explode). So I take the neg off then take the pos off whenever doing normally "hot" wiring on my vehicles. The reason I take the pos off second is if there is any chance of a wrench/bracket/tool dropping where the batteyr negative post is (or sometimes the neg cable just pops back over to the terminal as the cable has some spring tension) I like to be absolutely sure there will be no short. Shorts at vehicle batteries are very dangerous, I have seen the results of tools that short the system and seen where a couple of batteries actually exploded. Very bad mojo!
KDW4Him
18
Sep 1, 2021 05:47 PM
Adrian_X
Apr 8, 2020 02:36 PM
jhansen
21
Feb 15, 2017 04:26 PM
SparkieSRT6
Jan 11, 2016 10:49 PM
waldig
Aug 5, 2015 02:29 PM
