Fuel Pump Noise????
Old Aug 13, 2004 | 01:23 AM
  #41 (permalink)
AZ Outlaws's Avatar
Default
Hey Dan-O... The two thingies below are what you call quotes, or in simplier language... something you said.
Originally Posted by Dan Root
Hmmm 415 lb total wt capacity !On the doorjam!Hmmm
Hey AZ. that's not a humm it's a moannnnnnnn!! !!Or could be dragging something hah.As for you other A-holes I can't say.Good Luck hahaha..Oooooooooaaaaaaaaaaacccccccchhhhhhh.
Now for the fun part, trying to get through to you!!! Ready??? It took you two, count the quotes above... one, two tries but I'll bite and play your silly game for a few minutes.
So... what in the world are you babbling about this time and why are you bringing other people into this???
If you should decide to take the challenge and answer the previous question, please take your time and do it so we can understand you. On second thought, never mind and go take your meds as someone just suggested.
Oh, before I say over and out... I regretfully have a favor to ask of you. Please, if you have nothing constuctive or meaningful to add to a post, would you go play somewhere else???
Thank you very much.
Old Aug 13, 2004 | 06:17 AM
  #42 (permalink)
WesMichaels's Avatar
Default
Please Dan, start taking your lithium again.
I don't think his lithium is strong enough anymore.... It sound like it's time for Thorazine... In the early 70s I was flying medivac helicopers. When we had to transport psycho patients they would give them a good dose of Thorazine. It knocked them out and they stayed nice and quiet for the flight from Ft. Dix to Walter Reed. :lol:
Old Aug 13, 2004 | 10:02 AM
  #43 (permalink)
Tdancer2's Avatar
Default
Originally Posted by AZ Outlaws
The payload inside my car has no bearing on the noise... I hear it with or without a passenger in the car. I hope you slapped the idiot for making your size an issue.
I listened this morning on my way to work (I might have been speeding....) and you're right. I heard the humming with just me and my purse in the car. So that wasn't it.
As for the chrysler rep who made my jaw drop... I still haven't decided his fate.
Old Aug 13, 2004 | 10:44 AM
  #44 (permalink)
Dan Root's Avatar
Banned
Default
I was only responding to OTHER A-HOLES here sorry AZ........But if I just happen to be correct on the "Light pedal noise",I'm sure someone will post IT.!RIGHT !!
Old Aug 13, 2004 | 05:02 PM
  #45 (permalink)
jsisabella's Avatar
Default
Why does anyone waste their time responding to such nonsense, that seems to always get edited out?
And I think it would take Thorazine mixed with a Morphine injection to calm this guy down.....
Old Aug 13, 2004 | 05:27 PM
  #46 (permalink)
David Burns's Avatar
Default
We use VERSED in the field, it's a very nice paralytic.
Old Sep 18, 2004 | 02:22 PM
  #47 (permalink)
AZ Outlaws's Avatar
Default
Update....
The noise is coming from the rear differential and will only get worse as the car gets more miles on it. Took mine to the dealer yesterday. They pulled off the diff cover... way to much metal shavings etc in there. Corrective action: R&R the rear end. Parts should be here in a few day. Chrysler is well aware of this issue so anyone hearing the same noise, get it checked out.
T... better have them check yours out too.
_____________________
'04 Coupe SSB 6-Speed #02815
Crossfire International (XFi) Charter Member
Lights on... Wings up... Let's go!!!
(It's A Hook-Up Thing)
"Left Coast Hook-Up" Survivor... May 15, 2004
"Malibu Canyon Hook-Up" Survivor... Jul 17, 2004
"Phoenix Ice Cream-Up" Survivor... Jul 31, 2004
"LV Aw Shucks-Up" Survivor... Aug 21, 2004
gSin City Hook-Uph Survivorc Sep 11, 2004
http://xfcars.forumflash.com
Old Jul 2, 2023 | 10:16 AM
  #48 (permalink)
MoparDriver's Avatar
Default Re: Fuel Pump Noise????
Good morning AZ Outlaws;
Did you ever get this remedied?
3 years ago I replaced my fuel pump; if memory serves me correctly. it simply died.
Now, like you, three years later, I have a noisy fuel pump. It comes on like it should to pressurize the fuel line, then gets loader based on fuel demand. It never stops running. It is not the rear end, it is the same noise when I am stopped at a light. A constant Hum...
I believe these pump have a built in Pressure Regulator. If so, I need a new pump.
thoughts? - D
Old Jul 2, 2023 | 10:27 AM
  #49 (permalink)
thoughts? - D
You are replying to a nineteen year old post,
I don’t know the answer to your problem, sorry.
Old Jul 2, 2023 | 10:31 AM
  #50 (permalink)
Also, it is better to only post on one string at a time for the same issue.
Old Jul 3, 2023 | 02:43 PM
  #51 (permalink)
I didn't realize that my strings were overlapping, I have not found any relatively good answers for the Noisy Fuel Pump. But since my Post, I have absolutely verified the humming noise on my vehicle which I believe others have heard, was the External Fuel pump. Easy access and easy swap out..
Simply remove the fuel pump Fuse, crank the engine to relieve the fuel pressure, remove the plastic pan under the car, clamp the Hoses, detach the electrics, remove the hoses, unclamp and replace the canister, and reverse the order.
Just wanted others to know.
2005 Ragtop
Oct 3, 2015 03:01 PM
Oct 1, 2015 01:42 AM
Billy22Bob
Sep 28, 2015 08:08 PM
Billy22Bob
Sep 26, 2015 10:16 PM
Selbyl
Sep 26, 2015 04:15 AM
