Varta battery
Old Feb 9, 2013 | 07:26 AM
Default Re: Varta battery
Originally Posted by dinasrt
Yours succumbed to the cold; mine succumbed to the heat....... I think. Maybe my tender faulted and overcharged it? Not sure. What do you guys think? I removed it a couple of weeks ago to do some other work and discovered this. Here are a couple of pic.'s of it. Sorry for the crappy shots, but what it's showing is significant bulging on both sides of the long walls. It's been on the shelf for this couple of weeks and still has a full charge, but I'm afraid of it now. I'll be wrapping the next batt. in a heat reflecting material kit I got from DEI.
I believe mine went for lack of use. Too long on the tenders in a cold garage. We will treat the Braille a little better by driving the coupe more. As for the roadster. She is a weekender now but still sports all the goodies as the coupe with only the pulley difference. The little guys as you know are for racing. I was happy to get 2 yrs out of them. The Braille site is good reading btw. They have come a long way in the light weight technology.
Old Feb 9, 2013 | 11:02 AM
Originally Posted by oledoc2u
When you race Dave 30lbs could be a 1/10 of a second. The battery is the cheapest investment I have made searching for those 1/10th's as others addicted to drag racing will tell you. Why would they even make these batteries Dave. There must be a demand for them. lol. They now have lithium racing batteries. There cost is 4 figures. Used in all kinds of racing machines. They have a 4 lb battery. Does the same thing. So a guy like you Dave probably will never understand. Always looking for that next mod. Always looking to cut a 1/10th off at a time.
I will do you one better Dave. Add up those mods listed in my sig times two. You could own another SRT 6 Dave. Do you really think buying a battery is a big cost to me? And even with all that it will run with cars that bring 6 figures. So it's worth it to me regardless of what others think.
I thought from previous threads here that 100lbs = .1 second on these cars (SRTs)
Old Feb 14, 2013 | 11:26 AM
csteve0355's Avatar
LOL
I learned my lesson when a battery that had coughed once before and then suddenly died around midnight on a cold snowy Saturday. I never let my batteries get past five years these days, it was three or four years once but the batteries are much better now.
My '04 made Varta sits on the garage shelf all charged up and nowhere to go.
With the age of some of these batteries I would open the six caps on the top of them and refill with distilled water up to the bottom of the hole, batteries don't like the plates exposed.
I pulled off the caps, but know which level to fill to as there appears to be a two level marks?
Old Feb 14, 2013 | 11:52 AM
JEFASOLD's Avatar
I think that's a minimum and maximum.
Old Feb 14, 2013 | 12:16 PM
csteve0355's Avatar
That was my thought as well, but want to be sure before adding distiled water - the highest mark is about even with the bottom of the filler caps.
Old Feb 14, 2013 | 02:31 PM
You fill to the bottom of the hole, that allows some air gap between the top of the fluid and the top of the case. too much and it will leak out the vent holes and you do not want that on your car.
The vent holes should have a plug in at the firewall end and have a catch basin whatsit on the other end.
  • Check the water level every couple of months. It should be just touching the bottom of the refill hole.
  • Refill the battery, when needed, with distilled water. Don't use tap water, which produces corrosion on the terminals.
  • Don't overfill the cells. Just to the bottom of the refill hole is perfect.
Old Feb 14, 2013 | 04:37 PM
Every thing you find to lighten up you do without ruining the car. At least I do. I don't remove the seats or go to other extremes. The little battery for me frees up some space for another mod we will add later this spring once we do some data logging. Or I probably wouldn't have bothered. But these cars are very voltage sensitive. So whatever battery you chose. Chose a good one.
Old Feb 14, 2013 | 11:28 PM
Mongoose57's Avatar
Thank's to 180 for the heads up on a replacment battery,seems I will need one.
Since the last time, and even with extra running time my original Varta has given up the ghost,only two feeble cranks and then the tell tale click click click from the starter relay. I still am trying to charge up the Varta but after 3 days on 2 amp trickle ,and 6 hours on 12 amp charge I can only get 5 cells to fair on my hydrometer . Go figure one end cell is reading basically water but my multi meter showes voltage at 13 .6 volts
Cheers
Mongoose57
Old Feb 15, 2013 | 12:56 PM
csteve0355's Avatar
Thanks 180 - I just added distilled water to the level reccomended - yes the vent is pluged on the firewall side and there is a catch item on the other end.
Thanks again..Steve
Old Feb 16, 2013 | 12:30 PM
Mongoose57's Avatar
Well since I now need a battery I have been looking at lightweight VS standard, my calculations show that if waight savings were 30 lbs then on a 3,100 pound car running 14.6 in the 1/4 then you mathematically get 1.4 tenths or just over 2 HP. Well you have to ask your self if that increase is enoughf to warent the possible headaches ? I live in the Pacific North west, and most of the time in the winter it averages out to 3 c / 37.4 f so the 64 million dollar question is, Is this to cold for a lightweight that sits most of the winter and gets only weekly start ups Also note that the 06 service manuals state that @35 mili amp parasitic draw that 20 days may be enoughf to inhibit start in a battery that is not in top shape.
Cheers
Mongoose57
Old Feb 16, 2013 | 01:18 PM
dinasrt's Avatar
Cheers
Mongoose57
Unless you are racing for time,and/or wanting to create some space in the engine compartment for other Mods., then I'd say spare yourself the headache(jmho). One thing that I'm currently working on is adding a second lightweight battery(in parallel) in the trunk, in addition to the lightweight in the engine compartment. Each battery is only 20ah, so together I'll have 40ah. This hopefully will give me a little more peace of mind w/ my capacity, and still give me the space up front for my water/meth system. I'll still be plugging in the battery tender, but when I forget on occasion, I won't be stressing on it so much. And since I'll have the added power in the trunk, my plans are to install a 12v 50amp recept. for plugging in air compressor, and a standard 20amp recept. for spotlight or any other 12v goodies.
Old Mar 16, 2013 | 10:29 PM
Santa Fe Cruiser's Avatar
Lots of info about batteries but has anyone bought or tried to buy a new Varta to replace the old one? If so, who do you contact to order one. My 06 Limited Roadster is still on the original and it is working fine. But, it's now six years old and you can't let them go too long. I've only got 26,000 miles on it,.
Old Mar 17, 2013 | 03:00 PM
syfi's Avatar
Here's link to my post. Vartas are only sold in Europe but Johnson Control makes the equivalent battery here in the states under a couple of different brands.
https://www.crossfireforum.org/forum...tml#post728050
Old Mar 17, 2013 | 04:39 PM
shatteredhourglass's Avatar
Cheers
Mongoose57
I'm sure when you put a load on that battery it doesn't stay at 13.6 V!
blackpepper
Oct 4, 2017 06:09 AM
Reliableron
Oct 17, 2015 10:19 PM
o55ie18
Oct 5, 2015 05:50 PM
rmcdaniel12
Sep 22, 2015 01:20 PM
Valk
Sep 17, 2015 11:43 AM
