Dome light cover removal?
Old Jul 31, 2013 | 01:07 PM
TXCF's Avatar
Default Dome light cover removal?
I'm wanting to do the TPMS mod by moving the wire in the connector under the dome light cover. How do i remove that plastic dome light cover without breaking it?
Old Jul 31, 2013 | 01:12 PM
Default Re: Dome light cover removal?
Use a plastic upholstery tool, or a popsicle stick to carefully pry around the perimeter, it will eventually release.
Then there are 2 Phillips screws inside that you remove to get to the HomeLink connector.
Old Jul 31, 2013 | 02:53 PM
TXCF's Avatar
Thumbs up Re: Dome light cover removal?
Thanks bud! Worked like a charm and my first mod is complete. Great forum here.
Old Aug 23, 2013 | 07:45 AM
mugsy99's Avatar
How do I change out my dome light? Whats the best/easiest way without breaking the cover? ANy specific size bulb needed? Sorry,I am not mechanical at all and the easiest/simplist way would help alot. Thanks
Old Aug 23, 2013 | 07:57 AM
Mrmiata's Avatar
https://www.crossfireforum.org/forum...ghts-leds.html
Should fix you up..
Old Aug 23, 2013 | 08:50 AM
mugsy99's Avatar
Will NOT be doing the red,EVER! Will give this a try. Does power have to be unplugged to just change out 1 bulb?
Old Aug 23, 2013 | 09:17 AM
Mrmiata's Avatar
Other than working "overhead" it won't be an issue.. personally I'd rather unplug it and work with it at eye level..
Think green or blue would be my choice of color if I felt the need to change out myself.. LOL.
RED DOG
May 4, 2019 08:05 AM
reiji
Oct 15, 2015 10:50 PM
jtr2901
Jul 10, 2015 06:33 PM
tom2112
Jul 8, 2015 08:13 PM
joethejeweler
Jul 7, 2015 08:58 PM
