Trouble Light On BAS/ESP LIGHT
Old Nov 13, 2004 | 04:29 AM
saldous's Avatar
Default Re: Trouble Light On BAS/ESP LIGHT
Babeviper, any pics of your mods?
Old Nov 19, 2004 | 02:07 PM
Kit and Kat's Avatar
Well the Dealer had the car for ten days while we were away, and the light staid off for a whole 50 miles, now its back on... and thats after changing out the parts the computer said were bad..anyone got any ideas please?
Old Aug 20, 2005 | 10:02 PM
tacho0_4's Avatar
I had the same problem on 2004 Xf then I changed the brake pump pressure sensor and the warning BAS/ESP light goes off!!!
Old Aug 2, 2018 | 08:57 AM
Ed Mahoney's Avatar
BAS/ESP light on , did this fix your problem replacing brake pump pressure sensor ??? Where is sensor located ?
Old Aug 2, 2018 | 09:54 AM
Wow! New record,this thread is 13 years old.
Old Aug 2, 2018 | 01:39 PM
zip439's Avatar
Ed, there is a pressure sensor on the master brake cylinder; you can check to be sure the connection is clean and tight. It has also been found that a bad brake light switch will cause the BAS/ESP light to go on, but that usually also deploys the wing on the limiteds. Do not know if you have a SRT or N/A. The brake switch is near the brake peddle in the drivers footwell. Any codes?
Old Aug 7, 2018 | 09:02 AM
Ed Mahoney's Avatar
Yes 13 yrs old now you have a new record to write down seems like your thing ! Thanks for the heads up , I replaced the brake light switch last yr when light came on & no brake lights , so I think that switch is ok now have brake lights ! So will look at sensor on master cylinder .
Old Aug 7, 2018 | 09:04 AM
Ed Mahoney's Avatar
Yes 13 yrs old now you have a new record to write down , seems like your thing ! Thanks for the heads up , I replaced the brake light switch last yr when light came on & no brake lights , so I think that switch is ok now have brake lights ! So will look at sensor on master cylinder .
Old Aug 7, 2018 | 09:40 AM
Seems you repeat yourself.
Old Aug 7, 2018 | 01:17 PM
JSK's Avatar
JSK
There’s an echo in here.
Old Aug 7, 2018 | 02:46 PM
There's an echo in here.
Old Aug 7, 2018 | 03:13 PM
Ed Mahoney's Avatar
I did it on purpose seems like some people hard of hearing !!!
Old Aug 7, 2018 | 04:15 PM
Yea, but it's hard to know - see, usually, when we see dual posts like that, it's a glitch between your browser and the site.
Old Aug 12, 2018 | 11:23 AM
WHski's Avatar
Okay so this is BAS/ESP is a problem that just keeps on giving. My expierience with it and a variety of dashlights coming on started a few years ago. I somehow stumbled upon that by pushing on, or sometimes reseating the large connector on the ESP Unit, near the brake fluid resevoir, all the light issues would magically go away. Sometimes for months or a year or more at a time. However recentlly it has comeback and isn't going away as easily. I've blown out and cleaned the 60-some pin connector with 91% alcohol, that worked for a couple of week or so, but now is back. The connector seems loose. Yesterday with the help of my wife, while I gently "touch,push, move about" or apply pressure to this connector I can get all the lights out. So my question is, does anybody have any "retightening" techiniques? I tried looking and everythinnng is so small on this connector. Thanks, and this forum has been the best thing in owning these cars,
Old Aug 12, 2018 | 12:12 PM
That connector has a large latch on it that I think you pull up on to release and push down to lock. I have not taken it off in a long time so I am a bit vague on the details now. Do you have that latch?
Old Aug 12, 2018 | 12:59 PM
WHski's Avatar
Yes that's the one, you kind of flare out the sides then it swings up and slides off the pins/connctor at the same time.
Old Aug 12, 2018 | 03:38 PM
zip439's Avatar
1) It would be a good idea to get the codes read at an independent european/Mercedes shop. Just get the BAS/ESP codes read, nothing more. Maybe that would help in narrowing the problem to something more specific. Be sure they write them down exactly, so you can reference in the future should that become necessary.
2) Open the connector and using "DeoxIT D5" contact cleaner give it a good blast. Deoxit is both a cleaner and a lubricant. It will help cleans the contacts of corrosion. For about $15 -20 a can it is worth a try. You might also try a conductive grease BUT VERY CAREFUL NOT TO PUT SO MUCH ON IT COULD ARC ACROSS INDIVIDUAL PINS!!! I have a silicone base carbon black grease with micro bites of copper suspended in it which I tend to use on any connector I take apart and can get to the pins easily.
Old Aug 12, 2018 | 06:33 PM
  #38 (permalink)
WHski's Avatar
Thanks, I'll look for the cleaner you mentioned, I used some CRC Contact cleaner I picked up at Advance Auto today to no avail. Do you have a name for that conductive silicone grease you mentioned? That may be the fix for the "loose" fit. Appreciate the info, thanks!
Old Aug 13, 2018 | 09:06 AM
  #39 (permalink)
zip439's Avatar
Carbon conductive grease can be found at either eBay or Amazon; search " carbon conductive". I would guess the easyest to find is MG Chemical's # 8481 or 847.
Again I hope you will take your car to an Independent garage and get those BAS/ESP codes read. Most OBD II scan tools will not dig into the specific Mercedes systems codes far enough to glean the information you need. That is why I strongly suggest going to an automotive shop and get those codes read. It will help diagnose trouble in the BAS/ESP system. You can tell the shop your car is basically a 2004 Mercedes SLK 320. They will know what to do from there. DO NOT get a verbal feed back only: Be specific and be certain you have them write the specific codes on a piece of paper for you. TOO much is lost in verbal interpretation and shop BS. Get the codes.
Old Aug 13, 2018 | 11:58 AM
  #40 (permalink)
Some people get touchy when you tell them the post they are answering is ancient, the guy last posted on here in 2005.
I figured I was doing him a favour, welcome to the new age when everything is viewed as criticism or fake news.
