Newby question re power
Hi
I have an automatic UK Crossfire and it's great fun. I have however noticed a problem twice recently. I have been travelling at speed (70+ but not breaking any laws) when the car appears to drop out of gear and will not select anything. Pressing the accelerator has no effect (other than to rev the engine). Basically the car has no drive and glides to a holt. If I switch the ignition off and on, the car will restart and select gears and allow me to drive. My questions are:
What am I doing wrong ?
What are the possible problems ?
What do I need do to fix this ?
The car is under warranty at present.
Any help would be appreciated.
Cheers
Cheers
Hi
Cheers
Cheers
I would have the mechanic check the fluid level in the transmission. Then I would have the warranty company repair whatever is causing this to happen. If it is under warranty, make sure you get it looked at by a covered mechanic.
Check the transmission wiring harness for "wicking".
This is a known problem with these transmission, and in severe cases it can wick fluid all the way to the TCM under the passenger floorboard.
( I think they locate the TCM under the passenger floorboard on RHD cars, but I'm not sure )
davidc90
Sep 6, 2015 10:37 PM
