2005 Roadster power seat issue continues.
Old Aug 2, 2014 | 02:52 PM
jtrom's Avatar
Default 2005 Roadster power seat issue continues.
Drivers side power seat moves a few inches and stops. After a short pause seat will move maybe an inch and stop. This continues until you get to the spot you want. I have changed relay, lubed seat rails. Hopefully someone has had a similar situation, and could offer a solution to this madness !! Thanks if you can.
Old Aug 2, 2014 | 06:36 PM
Default Re: 2005 Roadster power seat issue continues.
If you could check for power at the connector under the seat going to the motor that moves the seat forward you could see if the power was intermittent or continuous.
If continuous the fault would be on the seat side or if intermittent the fault would be behind the plug.
You have to start somewhere.
Old Aug 4, 2014 | 06:11 AM
jtrom's Avatar
Thanks for the tip. It doesn't look like an easy place to get to through.
grip grip
Other Cars Etc
Aug 1, 2015 09:18 PM
Rusty475
Jul 13, 2015 10:03 AM
tom2112
Jul 12, 2015 04:41 PM
Mackel
Jul 6, 2015 10:54 PM
smfrycruzr
Jul 5, 2015 11:42 PM
