Is this normal operating range?
Old Sep 6, 2014 | 01:08 AM
power90801's Avatar
Default Is this normal operating range?
It seems a bit high but may be normal for the SRT-6, thought I'd ask those in the know...
Old Sep 6, 2014 | 06:30 AM
Indelibility's Avatar
Default Re: Is this normal operating range?
Yes, in the summer it's always a hair over the middle. With the cooler months it'll stay at the middle notch.
Old Sep 6, 2014 | 06:44 AM
dan gould's Avatar
94 degrees yesterday non SRT same temperature. Yours at 81 degrees would seem just fine.
Old Sep 6, 2014 | 08:00 AM
power90801's Avatar
The feedback is much appreciated, thanks again. I will consider it normal from here on out.
Old Sep 6, 2014 | 10:08 AM
Bill F's Avatar
I added Water Wetter to my coolant to help the engine run cooler.
Old Sep 6, 2014 | 12:56 PM
05roadsterguy's Avatar
Mine runs from just under the mid line to just over, depending on circumstances. It seems rock solid though, even in long desert drives and stuck in traffic for 2 hours on a 85 degree day.
Old Sep 6, 2014 | 05:29 PM
Red Runner's Avatar
I hope you realize the digital temperature on the dial is the outside temperature from sensors located behind the front fascia & has nothing to do with the coolant temperature.
Stan
Old Sep 6, 2014 | 06:48 PM
Mine runs 186 cruising at 55-60 w/o A/C, 195 with A/C. ( UltraGuage )
186 = just below the middle mark, 195 = half a needle above the middle mark.
Old Sep 6, 2014 | 08:23 PM
velociabstract's Avatar
Mine is the same as yours. Your right at 204º in case your wondering. Normal for summer months. Numbers courtesy of Dashdaq.
Les
Old Sep 7, 2014 | 09:26 AM
Well, I try to keep mine closer to full, but my foot keeps it closer to empty, just sayin'........
Old Sep 7, 2014 | 06:25 PM
Wrong gauge Doc ( but then, you probably know that )
BTW: 15 gal fuel x 6.073 lbs per gal = 91 lbs.
Running at 1/4 tank saves you 68 lbs, would this make much difference in a 1/4 mile run ?
Old Sep 7, 2014 | 08:08 PM
My gauge never gets to the middle mark, Ultragauge shows a temp of 186 to 190.
But I had the "-10C" mod done to my car for $50 by Buckhead Imports and I recommend it to everyone. My fan's operating parameters are lowered 10C/18F by the mod, that is, the fan runs at much lower temperatures. I have no idea why they put a 190F thermostat in there and THEN didn't program the fan to maintain 190F. But now, mind does just that.
roar
Jun 15, 2022 11:46 AM
Apr 28, 2016 02:04 AM
nataliefs
Oct 5, 2015 01:03 PM
mecdoux
Sep 20, 2015 12:32 PM
lazorouss
Sep 11, 2015 09:16 AM
