Problems? Any help.
New to forum. My brother has a 2006.
At cold start it seems to take off slow.
Once warmed up it appears to get stuck when you punch it, but then it will shoot.
Issue is sparatic. Does not leak any fluids, but assuming it needs a transmission flush.
Anyone know what might cause???
Also has a check engine light. Going to have that checked today.
get the code read... that isn't a transmission problem...it is a throttle problem. Could be as simple as a CPS replacement or a throttle body problem, but get the code read. I am assuming this isn't an SRT6...
Well, sometimes it can be the start of a CPS, or Crankshaft Position Sensor, starting to go bad. Rough idle, hard starting, rough on take off.... It will show it's ugly head one day if that is the case. Less than a $40 fix and do it yourself kind of thing...there is a "how-to" on here if you need to do that...
skeet370
29
Sep 18, 2015 05:53 AM
steps
Sep 12, 2015 09:23 PM
