skreem module??? need help
Old Oct 10, 2014 | 05:13 PM
stanced E46's Avatar
Default skreem module??? need help
Car cranks 2 times does nothing after no click...disconnect battery for few seconds..cranks 2 times does nothing again , changed cps changed rcm , checked the starter for the hell of it all good new battery as well anyone know what it might b? Don't wanna keep dumping money on parts and it doesn't fix the issue
Old Oct 10, 2014 | 10:37 PM
Default Re: skreem module??? need help
Frustrating stuff. Does sound like the skreem module. With the cps and rcm issues you either have crank and no start, or no crank. Read thru the thread on the skreem thread.
Old Oct 10, 2014 | 10:39 PM
Do I take to dealership and asked for a new skreem and key? Or can I just asked to reprogram the key and see what happens
Old Oct 11, 2014 | 09:55 AM
usually the module itself is the problem. I haven't dealt with this problem to date, so I can only send you to those who have. That thread describes most of what you have to do. Maybe someone who has will chime in....good luck, I know that is frustrating. I hate the day I have to tear into the dash to look for the module.
Old Oct 11, 2014 | 10:32 AM
Oh I can tear into the dash and do it myself? Lol as long as it's not to pricey w.e works just an adventure for me hahaha
Old Oct 11, 2014 | 10:47 AM
yes, it is something you can fix yourself. You don't want the boys at the dealership in there...
Old Oct 11, 2014 | 10:50 AM
Thanks uve been really helpful I appreciate it ^_^ I owe u a beer lol would u happen to know where I can order a skreem and do u know if I have to program it or just plug and play?
Old Oct 11, 2014 | 11:09 AM
I can only tell you to read thru the process. I know you can buy new ones, and I know there is some programing of the key. There is a how-to on it somewhere as well. Module is located behind the instrument cluster. I have never been in there for any reason thus far, so I am of no help. I hope I never have to. Some of the "locking" mechanism is in the trunk area. Moisture getting in there has caused problems as well, with locking and unlocking. But, the starting issue is sometimes related to the skreem module. In your case, the skreem seems to be the problem. Like I stated earlier, with the CPS, crank no start, with the CRM, no crank. In your case, cranks a couple of times, then nothing. Unplug the battery, replug, repeats...that is classic skreem symptoms.
Old Oct 11, 2014 | 11:11 AM
I'm gonna try to replace it myself thanks do u know how I can reprogram or the right thread that will lead me to it?
Old Oct 11, 2014 | 12:32 PM
just keeping up while I work... punch "skreem" into the search feature above and read thru all those threads is the best bet. I will be outside working for the most part the rest of the day. Getting ready for dreaded winter....and then working on the cars this evening. I will check in later.....
Old Oct 11, 2014 | 01:34 PM
Mrmiata's Avatar
Just a quick check here.. you didn't just replace the fob case with a new one.. right?
REYMARTZ
22
Aug 7, 2021 12:37 PM
jhansen
21
Feb 15, 2017 04:26 PM
NORDVIK72
Aug 30, 2015 08:22 AM
NORDVIK72
Aug 25, 2015 11:43 PM
da pink
Aug 12, 2015 05:20 PM
