Searched mystery no start... want to confirm a few things
Old Jan 3, 2015 | 07:32 PM
verdugo135's Avatar
Default Searched mystery no start... want to confirm a few things
My first post. Just bought an 04 Crossfire with a no start issue. After searching and checking the car I've ruled the out the RCM. After disconnecting and reconnecting the battery the car will start and die 3 times. I'd have to disconnect and reconnect the battery to get the vehicle to do this again... therefore I'm under the assumption that I've got a SKREEM problem. The only difference to others here is that my cluster does not work. The only lights that come on are the red battery light, airbag light, and a yellow light which i think is the exterior light fault warning. No mileage or anything else, its as if the cluster is completely disconnected. Radio comes on, although buttons are inop (unrelated I think). Blinkers and hazards don't work either, probably related to the cluster prob. My next step is the dealer unless anyone has any ideas.
Old Jan 3, 2015 | 09:10 PM
verdugo135's Avatar
Default Re: Searched mystery no start... want to confirm a few things
Turned out to be just a burnt fuse for the cluster. I jumped the gun and forgot to check the easiest first. Mods you can delete or leave this here for the next guy that jumps the gun... lol.
Old Jan 5, 2015 | 06:39 PM
Now THAT is a new one!
Old Jan 15, 2015 | 02:13 PM
Futureknows's Avatar
hi Verdugo,
Which fuse was it?
Very strange to see that even a fuse can cause the MNS issue.
Gives new meaning to "failsafe"
Old Jan 16, 2015 | 01:33 PM
05roadsterguy's Avatar
Originally Posted by Futureknows
hi Verdugo,
Which fuse was it?
Yep Yep! That's the way this forum works. If you find a fix, share it with everyone. A burnt fuse for lights and a MNS would be the right place to start someone looking. Which fuse was it? and why did it burn?
northwest_crossfire
May 30, 2016 05:19 PM
Dec 2, 2015 12:49 AM
austinforever
U.K.
Sep 13, 2015 08:24 AM
RiderJC
Sep 7, 2015 11:19 PM
aerobluehal1
Canada
Sep 3, 2015 10:15 AM
