Door lock issues '04 crossfire
Old Apr 15, 2015 | 10:36 PM
chturner's Avatar
Default Door lock issues '04 crossfire
Just got an 04 crossfire as a gift for joining the Air Force. I'm trying to figure out my door locks. I can get my doors to unlock when I lock them manually, but the door lock button will not lock them. Also, when I lock my doors with the key hold on the handle, only the driver's side (the door I insert the key into) will lock. I know there's a module/air pump in the trunk but I'm assuming that is not a problem, being as I can unlock the doors from the button inside. Any info will be appreciated. Thanks guys
Old Apr 18, 2015 | 10:25 PM
Default Re: Door lock issues '04 crossfire
Congrats on joining, I spent 23 of my best years serving. If I understand you, your not able to lock the doors with the FOB lock button? Will the FOB UNLOCK the doors? If not, I would suggest the FOB batteries need replacing. If the FOB unlocks the doors but doesn't lock them, I would suspect the contact under the FOB button. Right now I can confirm from your post you can use the key to lock/unlock the drivers door with the key in the FOB. We also know the interior lock/unlock button works as well? We (I) need just a little more clarification. Does the actual FOB buttons do anything (lock or unlock). Finally, does the panic button on the FOB work? It would be an additional clue to narrowing down your problem. I also suggest you download your owners manual .pdf, and if your handy with some tools and like to do your own work, download the service manuals. These two things will answer quite a lot of questions about the systems and components in your new crossfire! Oh, welcome to the forum!
Old Apr 18, 2015 | 11:01 PM
KDW4Him's Avatar
And if it's the only FOB he has order one from Needswings, soon.
Old Apr 18, 2015 | 11:11 PM
Mrmiata's Avatar
Just some friendly advice here.. Don't post multiple threads of the same issue. Advice is free here and chasing you down to help doesn't pay extra.. You can always click your name in a post and find any previous post you may have made.
https://www.crossfireforum.org/forum...tml#post833585
syfi
Jun 22, 2015 07:23 AM
mhajek18
Jun 17, 2015 01:35 PM
MJPowers
Jun 8, 2015 02:34 AM
gobraves423
Jun 6, 2015 07:03 PM
mouserider
Jul 26, 2003 11:47 PM
