Dash light!...?
I have this light showing up every once in a while. I have not been able to find out what it is! I checked all my fluids and everything seems to be ok... HELP! 2006 Roadster XFire
Thanks much...
Thanks much...
Hi Frogwash, The light indicates that the fluid in your radiator is low. Check the overflow tank for the correct level. Park car on level ground & check when fluid is cold. There is probably a sensor in the overflow tank that may need to be cleaned or the electrical connector is loose. You need to get an owners manual, available at the dealers if you want a new one or ebay for used. Also, you need to download the service manual available on the forum. This should be an easy fix.
"The light indicates that the fluid in your radiator is low. Check the overflow tank for the correct level. Park car on level ground & check when fluid is cold. There is probably a sensor in the overflow tank that may need to be cleaned or the electrical connector is loose."
So If I check the level and it's down, fill it to the proper level ... sounds like I don't need to clean or fiddle with the connector if the light does not reappear. I just moved and cannot find my service/owners manual. Going to sell the car unfortunately
.. Just don't have garage space anymore.
Thanks for your help...!
Danyuhl
Nov 2, 2019 05:18 PM
xfClifford
27
Nov 10, 2015 10:08 PM
