Need To Go Lower!!!
Old Feb 26, 2005 | 04:17 PM
jamil's Avatar
Default Re: Need To Go Lower!!!
cutting eibach spring is too dangerous, it will change the resistance of the material and you will be in real danger.
jamil's Avatar
Bad idea cutting spring, try short
Old Feb 26, 2005 | 05:07 PM
xfirerealtor's Avatar
after changing the spring pad it lowered about 3/4 - 1/2 in and when i alligned it, it came out to factory specs.. all green... it was perfect...
Old Feb 26, 2005 | 08:38 PM
Dan Root's Avatar
Banned
Thanks i'll check mine. my car wasn't that high to begin with. i'm curious if i could just change pads and not springs i might put back my original springs in the rear and get back stock ride!
Old Feb 27, 2005 | 12:12 AM
theotherbrit's Avatar
Angry Re: Need To Go Lower!!!
There is always one moron in a group like this.
No it won't!
Show me the data that says that localized heat, the cutting area, changes the characteristic of the metal.
Can you?
Old Feb 27, 2005 | 11:35 AM
andrew's Avatar
-C-I-C-C-I Associate Member
No it won't!
Can you?
metal characteristic...it would not see change imo.
ride is a completely different story...as far a cutting...it all depends if they are progressive rate springs or not. if its a dead coil...cutting is fine.
would i do it to my car...no...but you can.
Old Feb 27, 2005 | 01:38 PM
pnsji's Avatar
The eibach springs for our car is not progressive for all 4. only 2 of them are progressive.
As far as cutting spring, I would not recommend doing that, but if you really want to do it, it is okay as long as it is not the OEM spring you are cutting.
Old Feb 28, 2005 | 04:50 AM
911split's Avatar
pnsji,
For our XF (SLK) Eibach's, which pair of springs are progressive: the front or the rear?
Thanks.
Old Feb 28, 2005 | 03:07 PM
pnsji's Avatar
I believe the rear springs are the progressive one. It has been a while since I install the spring to my car.
Old Mar 1, 2005 | 04:28 AM
HDDP's Avatar
Careful guys. front wheel clearance is at a minimum. If you lower too much with the same size tires, you're going to grind like hell on the fronts. H&R springs will take you down the furthest of any aftermarket product, 1.5". The spring pads are another option and can be purchased through MB. Or you can shave the pads yourself when you're replacing the springs.
Now you're looking at probably -1.25" camber offset which can't easily be adjusted with the OEM set-up and I haven't found an aftermarket camber kit for the car yet. So, now you've just got yourself a car thats going to look like a duck from the front and rear and will burn through the inboard edge of your front tires in 10k miles +/-. And you'll probably create a huge amount of oversteer which will send your *** spinning on the first wet corner you hit a little too fast... But what the hell do I know ?
Old Mar 1, 2005 | 02:58 PM
pnsji's Avatar
HDDP,
I have 19x8.5" with eibach pro kit and 235/35/19 and no rubbing so far. The clearance between my tires and steering knuckle bolt is about 3-5mm. No rubbing on the fender whatsoever.
Shaving the spring pads are not recommended. The rubber pad is a very hard rubber. Unless you could shave it evenly, then do it.
The front, you could buy eccentric bolts from the benz dealer to correct the camber.
For the rear, my friend make camber arms:
Old Mar 1, 2005 | 03:39 PM
guys i have some rubbing when i am backing out of my driveway and I cut it harddddd. thats all.. and when i put the eibach pro kit in the front and put the 5mm spring pads in the front i took it to chrysler and they alligned it and its in factory spec and rides great...i have 19's in the front
Old Mar 1, 2005 | 03:43 PM
pnsji's Avatar
What's the offset of your front wheels? and wheel dimension?
Old Mar 1, 2005 | 06:28 PM
HDDP's Avatar
Originally Posted by pnsji
HDDP,
Good info, I had major problems with front wheel well rub after I installed the Eibach / Koni combo. it was only on hard, off-cambered corners at the track though. And when backing-up, turning. I wonder if the QC on the Eibach spring size is not perfect. My camber has been adjusted to -.5" and I still run the OEM wheels and Conti's on the the street. Could be a car-by-car issue, because SASKINS hasn't changed his suspension yet but is getting rub when he is turning in reverse !
I like those tie arms... where'd you find them ?
Old Mar 1, 2005 | 06:32 PM
pnsji's Avatar
Those custom camber kits runs about $275 for the pair. They are adjustable arm as supposed to the fixed OEM arm.
edit:
Actually I just saw your gallery and it rubs on the plastic cover. Maybe try to push the wheel out 10mm by spacers?
Old Mar 1, 2005 | 06:43 PM
pnsji's Avatar
BTW, does it rub on both sides??
Old Mar 1, 2005 | 06:50 PM
andrew's Avatar
mine also rubs only in reverse when the wheels are turned hard as well (front area/both sides)...it doesn't bother me. it's not doing any damage...no biggie imo. i am running stock rims and tires with eibach & konis. i am using spacers...it rubs with or without spacers.
Old Mar 1, 2005 | 06:52 PM
  #38 (permalink)
HDDP's Avatar
edit:
Actually it rubs on the inside wheel-well at about the 11 o'clock position on the inboard side of the wheel. Wheel spacers are out of the question since I run the car on the track alot. I had some issues with wheel spacers a few years ago on one of my other sportscars and SCCA DSQ'd my season points.
Back to the tie arms... do you have a vendor for them or were they custom made ?
Old Mar 1, 2005 | 07:05 PM
  #39 (permalink)
pnsji's Avatar
So it only rubs on the passanger side? I know that Mercedes has problem with passanger side only.
The arms are custom made. If you need one, please send me email at sirwan at gmail dot com.
55chevy
Jul 22, 2024 02:31 PM
Oct 1, 2015 01:42 AM
Power Sedan
Sep 20, 2015 09:24 PM
ayebb
Sep 18, 2015 03:35 PM
waldig
Sep 17, 2015 10:35 AM
