Battery Removal
Old Jul 29, 2016 | 10:05 PM
Default Re: Battery Removal
Every battery that I have seen had a vent hole at each end, a plug goes in one and a vent trap or vent hose goes in the other. which end the plug goes in depends on the layout.
Does this battery have a vent ?
I never noticed if it does
Old Jul 29, 2016 | 11:31 PM
If you study the photo carefully you can see the boss at each end where the vent or plug are inserted. They are roughly inline with the word 'BATTERY' printed on the top on the left. So yes that battery has vent holes. The one against the firewall should have a plug in it and the front facing hole should have a vent trap or a hose that directs any spillage away from the car body. We have seen the damage that the acid can do.
My AGM battery has vent holes in it, as the chemical reaction in all lead/acid batteries produces gasses.
Old Jul 30, 2016 | 08:58 AM
velociabstract's Avatar
Nanoseconds is all it takes. I going to assume this thread is mostly venting about getting old and weak. I resemble my remark but geez. It won't lift straight out, ok, won't move side to side, ok, won't move back, ok, forward and out at an angle.
Les
Old Jul 30, 2016 | 10:01 AM
Les
I moved my one forward just to look at the bottom clamp, it is not necessary that it be tightened, it may or may not form a lip for some batteries to go under. I think it does not from what I see.
I think that some people will tend to over tighten the top clamp strap, I tighten it so that it will still deflect by moderate pressure pushing it down by the nut.
Old Jul 30, 2016 | 03:51 PM
I think that some people will tend to over the top clamp strap, I tighten it so that it will still deflect by moderate pressure pushing it down by the nut.
I agree with this comment. Holddown clamp really only needs to be tightened enough to keep battery secure. The battery is such a tight fit in the tray, it isn't going anywhere. Add the fact that the battery cases for the 48H6 Series used in our Crossfires differ from one manufacturer to another. The Duracell Ultra 48H6 I got from BatteriesPlus earlier this year has the case height slightly taller. So the holddown strap had to be slightly bent for it to lay flay across the top. Otherwise, the holddown clamp applied too much pressure to the edge of the battery case on the fender-side.
Later,
xxfirerican
Jul 11, 2011 06:53 PM
Crossfire Princess
Apr 8, 2011 06:32 PM
FTroopChief
Apr 20, 2008 08:07 PM
mrphotoman
Apr 2, 2008 05:18 AM
Extensive
Oct 14, 2007 02:28 PM
