BAS ESP Light comes on intermittently
Old Oct 13, 2016 | 10:31 PM
Default Re: BAS ESP Light comes on intermittently
Originally Posted by waldig
I have the light AND my cruise control works???????????Woody
Maybe it depends on what is causing the light to come on.
Old Oct 22, 2016 | 01:24 AM
John&Terry's Avatar
Hello,
It has been awhile now, and neither problem has come back. There is no longer a P0410 code, or any other codes. The BAS/ESP light problem has also gone away.
Although the Dealer was expensive (what dealer isn't?), they performed the work when they said they would, corrected the problems entirely, and honored the warranty without even charging us a penny. It was fortunate that we had a warranty, and a Dealer that would honor it.
We have been driving Pearl around quite a bit before the warranty expires, in case something else pops up.
Thank you everyone for your helpful suggestions.
John & Terry
Old Oct 22, 2016 | 08:29 AM
I think our friend in Arizona provided this photo, if so, I'd sure trust it:
Your friend in Canada provided that picture and it came with a caveat, one of the fuses appeared to have two functions and I am not sure if that is true. I kept saying I would look into it more but I never did.
Old Oct 22, 2016 | 09:46 AM
Steve Jr's Avatar
I was kind of confused by that. When I replaced my fuel filter, I pulled the one marked 4 (singularly), tried starting the car , with no response an lost only about 1/4 cup of fuel out of the lines. Caps on the filter ends an Olla ,I was done. But, I kept wondering, "what's up with that other fuse powering the fuel pump too?"
Sorry John this has nothing to do with your OP.
Edit: curiosity got the best of me, so I pulled the doubled marked fuse, car started an ran fine....reminder, its leave season, clean out your cowl cover.
Old Oct 22, 2016 | 10:38 AM
Ah! Did the air pump run?
Old Oct 22, 2016 | 02:58 PM
Steve Jr's Avatar
No it did not, that IS the air pump relay fuse. Had to double check. Let engine cool an you only have 2 1/2 minutes of the pump running time to probe wires an pull fuses. Could have pulled RCM an force run it, but the "honey-do-list" is today!!!
Old Oct 22, 2016 | 08:42 PM
Steve Jr's Avatar
I think, I understand why one fuse has a duel purpose,it's just not in that configuration. The 04 manual, 8W-10 pg.20,21 shows the engine control relay and the air pump relay begin tied together. Its showing engine control fuse 1an 2. 2 being tied together to the air pump relay. Testing across the fuses ,all are hot ,except 3 and 5, then when you turn the ignition on, they are energized together....
Old Oct 24, 2016 | 10:56 AM
Originally Posted by pizzaguy;875847
[IMG
https://cimg4.ibsrv.net/gimg/www.crossfireforum.org-vbulletin/799x432/80-rcm_relays_46d7672629e836df7affc409be1b49099360f26 d.jpg[/IMG]
I have updated the RCM photo.
Old Oct 24, 2016 | 01:26 PM
Steve Jr's Avatar
Old Oct 24, 2016 | 01:37 PM
sirharper's Avatar
Absolutely. If it's one of the speed sensors the cruise control will be disabled. If it's the yaw or steering angle sensor cruise can still work.
Old Oct 24, 2016 | 03:59 PM
lf these two sensors are out then I would think that for safety sake the cruise would shut down, it shuts down if the car seems out of control.
Old Oct 24, 2016 | 04:07 PM
sirharper's Avatar
You'd like to hope so but that doesn't seem to be the case. Cruise worked fine when my Yaw Sensor was out. I can't 100% say the Steering Angle Sensor wouldn't disable it also but that seems to be the findings here. Some are reporting cruise works with the BAS/ESP light on, some aren't. It has to just be a matter of which sensor has failed.
Old Oct 24, 2016 | 04:11 PM
sirharper's Avatar
Here's a question though, has anybody had a wheel speed sensor fail where the BAS/ESP light came on and NOT also the ABS light? That could help diagnose at least which type of sensor failed.
njrotcusa
Mar 8, 2017 03:51 PM
stz561
21
Nov 29, 2016 11:55 AM
Alem12
Sep 7, 2016 08:20 PM
REYMARTZ
Sep 4, 2016 06:56 PM
sjrcrossfire
Aug 22, 2016 08:59 PM
