74mm throttle body
74mm throttle body
So is this the plug and play 74mm throttle body?
http://www.ebay.com/itm/322592268044
Do I need to buy anything else for the swap. I looked at a few post but I'm confused.
Re: 74mm throttle body
01-06 MERCEDES V8 E500 S500 CL500 ML500 CLK500 S430 THROTTLE BODY ACTUATOR 61416 | eBay
CLICK
on
Like George said below, make sure you get a new 'O' ring (don't reuse the old, its deformed). You can hold it in place with some petroleum jelly so it stays in place while assembling. IF after you run it a couple of cycles (so the car learns the new TB) it still hesitates/stumbles/runs rough, you just might have lost the groove /'O' ring alignment while assembly. It is usually where the vac leak is. That is why it is so very important to make sure it stays in place while assembling the TB to the intake. Good luck, you'll LOVE to peppier response.
Right on George, a new 'O' ring is a MUST!
M4rCu5 (10-29-2020)
Just follow Reckahs PDF for all instructions, it tells you the O-ring part number as well. If you know of a supplier of O-rings you can take the old one there and save some money. A Viton O-ring should be used because of the highish temperature.
The PDF talks about a larger MAF but you can ignore that info if you are not adding them.
For better performance you should add the larger 74mm MAF.
The MAF sensor in the car now is fine, even if the MAF itself is changed to the 74mm one the MAF sensor now in use is put in the 74mm MAF sensor.
You will find the number in this PDF.
CLICK
CLICK
The MAF sensor rarely fails and the MAF never.
M4rCu5 (10-29-2020)
M4rCu5 (10-29-2020)
