Ignition coil, wires, boot and plugs
Old Dec 7, 2017 | 11:46 AM
Bzak1pgh's Avatar
Default Ignition coil, wires, boot and plugs
I need to replace my sons plugs and I'm going to replace the wires and coils too. I'd like to upgrade them to a higher performance type persay... any suggestions? I'd like to stay under $400 if possible. .. any help or links would be greatly appreciated!
Old Dec 7, 2017 | 12:13 PM
DTMenace's Avatar
Default Re: Ignition coil, wires, boot and plugs
Bzak1pgh
Check the most reliable supplier for the Crossfire, NEEDSWINGS, they are active on our site. The down side of your request for all of the parts is quite low. Your not going to buy everything for that $400 or less.
BTW, what Crossfire model does your son have at this time?
Good Luck.....
Dennis
DTMenace
Old Dec 7, 2017 | 12:15 PM
Bzak1pgh's Avatar
05 Crossfire V6 base
Old Dec 7, 2017 | 12:33 PM
DTMenace's Avatar
Here's the link for ignition parts for your son's base model ($209 for wires, plugs and gauge) Coils @ $99.95 each and you need 6. Looks like $800+ for the parts...
The Crossfire is not a cheap car to work on, even the simplest of repairs.
Click on link below
Dennis
DTMenace
NeedsWings Performance Products. Ignition XF
Old Dec 7, 2017 | 01:00 PM
Bzak1pgh's Avatar
Click on link below
Dennis
DTMenace
thank u! At least I have a good place to start! Thanks for ur time!
Old Dec 7, 2017 | 01:12 PM
Replacing the coils is a waste of money if they are not causing any problems and then only replace the faulty one not all of them.
Old Dec 7, 2017 | 06:54 PM
RED DOG's Avatar
I agree . . . I was just going to ask why he thinks that he needs to replace the coils?
Old Dec 7, 2017 | 07:32 PM
waldig's Avatar
Talking Re: Ignition coil, wires, boot and plugs
If you suspect the coil packs........just move / swap them to see if the problem is associated with the coil or not. Id not replace them till I need to. Enjoy, Woody
Old Dec 7, 2017 | 09:52 PM
Padgett's Avatar
BTW plain Crossfire is the same engine as a Mercedes SLK320 (M112 engine). OEM coils were made by Bosch like most of the electrics. Gap plugs at .8mm (.032").
Old Dec 7, 2017 | 11:45 PM
Spark gap is 1.0 mm (.039")
Old Dec 8, 2017 | 04:13 PM
I did plugs and wires at 100,000 miles on the Graphite - made a world of difference and got rid of my misfire and O2 codes. I went to Rob at Needwings for the parts.
Yea, I don't see a reason to replace coils at all.
Old Dec 8, 2017 | 07:46 PM
Padgett's Avatar
Is this the right coil for my N/A '07 ? Bosch Original Equipment 0221503035
Old Dec 8, 2017 | 10:52 PM
Bzak1pgh's Avatar
Thanks guys! I'll take the advice and leave the coils alone..
Old Dec 10, 2017 | 05:51 AM
djohn14296's Avatar
Thumbs up Re: Ignition coil, wires, boot and plugs
Not to take anything away from Needswings, but you can order the coil packs from Amazon for $40/$50 less. Look up the packs for the MB SLK 320. They are the same. NeedsWings maybe high performance, unknown, but you ask them. They wires and spark plugs are excellent.
Old Dec 13, 2017 | 07:53 AM
RED DOG's Avatar
Default Mods . . . Please move this thread to the proper category
Mods: Please move this thread . . . Thanks,
Old Nov 22, 2019 | 09:55 AM
mariontr's Avatar
OK when trying to get the clips off the coil pack I broke the tabs to remove them how easy to replace the 3? Ignition pigtail connector is the best I could think of.
Old Nov 23, 2019 | 02:13 PM
RED DOG's Avatar
The plastic clip release gets brittle over time and they break very easily. You really don't need that clip but you can use a small cable tie to secure the connector to the coil pack if you wish.
Old Dec 2, 2019 | 09:51 AM
mariontr's Avatar
Thanks RedDog
alexdc
Dec 1, 2017 06:54 AM
ShawnQ
Sep 30, 2016 03:19 PM
airborne82nddiv2003
Oct 27, 2009 11:55 PM
TVT_DESIGN
22
May 11, 2008 06:56 AM
The Toy
Sep 8, 2006 06:58 PM
