Engine Treatment
Old Mar 7, 2018 | 03:14 PM
wgc's Avatar
wgc
Question Engine Treatment
Is it ok to put Lucas Engine Treatment in the engine oil 05 Crossfire??? gary
Old Mar 7, 2018 | 04:53 PM
philosophico's Avatar
Default Re: Engine Treatment
I wouldn't, these engines don't burn oil so I see no reason to add any additive to the engine. Just do your regular oil changes and these motors will last forever.
Old Mar 7, 2018 | 07:40 PM
wgc's Avatar
wgc
I have a small ticking noise in the driver side valve train and was hoping it might help. it only ticks after it warms up. Gary
Old Mar 7, 2018 | 08:24 PM
everybody has the same ticking it is normal for this engine, lots of post on it,, search.
Old Mar 7, 2018 | 11:30 PM
All the benefits claimed by the maker of this additive are done by any good oil such as the Mobil 0W40 we use generally. So why waste your money?
Old Mar 7, 2018 | 11:37 PM
wgc's Avatar
wgc
Red face Re: Engine Treatment
Thanks Will not put engine treatment in oil I appreciate it
Old Mar 7, 2018 | 11:41 PM
wgc's Avatar
wgc
Thank you I will not use the Lucas in oil Thank you. gary
Old Mar 10, 2018 | 01:11 PM
wgc's Avatar
wgc
Ok will change oil soon and if that does not stop the ticking I will turn the stereo UP I really appreciate all the help. Gary
Old Mar 10, 2018 | 09:58 PM
Speedy4x4's Avatar
And if that doesn't work
Get a bigger stereo
I use Lucas every other tank of fuel, but in the m112 engine, nothing in oil, been thinking about adding some seafoam for 2-400 miles before oil change.
My clicking is when it is cold.
Find me some cams at a descent price and I will pull valve covers off and fix it.
Old Mar 11, 2018 | 09:05 AM
I run 5W40 Mobile 1 and my lifters are quieter. I tried 5W50, but at temperatures below about 55F, it is just too thick for a cold engine start - so I changed to the Daimler-recommended 5W40. Keep in mind that "0W40" sticker is ten or more years old now and that any MB or Chrysler dealer will put 5W40 in there, as that is what is recommended. 0W40 is approved, but 5W40 is recommended these days.
Of course, the injector clicking is never gonna go away.
Notice there are more 5W40s on the list than any other weight:
https://bevo.mercedes-benz.com/bevolisten/229.3_en.html
Old Mar 11, 2018 | 09:19 AM
I am thinking that may be just a little bit optimistic, by my reckoning your oil and 0W40 are the about same viscosity at engine temperature.
Old Mar 11, 2018 | 10:05 AM
Speedy4x4's Avatar
Soooo, are you saying it is approved to run rotella?
additives are different in 0w40 and 5w40 because 5w40 is diesel oil, that is why there are a lot more options, it is everywhere.
rotella can put 1,000,000 moles on a cat engine so why wouldn't it be good in ours?
I just always used Mobil 0w40.
And with these damn disposable engines, i want what i can get most mimes out of.
not like there are parts for these engines to make it worth rebuilding or upgrading...
maggy55
Sep 7, 2017 03:18 PM
NovaCharged
Oct 26, 2009 09:03 PM
CrossfireLTD
Jul 12, 2009 02:21 AM
boomer
Jun 5, 2004 06:54 PM
boomer
Jun 5, 2004 01:15 AM
