DRB III Emulator?
Re: DRB III Emulator?
Oh, weird. Let me check permissions right quick maybe I didn't set it right.
Edit: Permissions look ok, I wonder if it's because I didn't specifically request a viewable link. Try it again. It should say an error like can't verify file because it's too large, but that's fine anything over 250 or 500mb google can't scan I believe.
https://drive.google.com/file/d/1hcS...ew?usp=sharing
I was able to download it. You just have to ignore the warning about the scanning and select download.
Edit: I wonder if it's the VM hardware settings? I'll take a screenshot when I'm back home of the VM Machine details and Workstation version to see if that might be the issue? I don't ever use workstation, only ESXi so I'm not sure if it's the same.
If you want to bring the Workstation VMDK over to ESXi you'll have to type this in SSH to convert it.
'ssh root@esxi (whatever the esxi IP is here)
cd /vmfs/volumes/datastore1/ (Whatever you named the datastore)
vmkfstools -i 'Windows_7_-_DRB-disk1.vmdk' DRB_ESXi_Converted.vmdk -d thin'
nemiro (12-02-2023)
No problem, what happens with Java? When you click the IE shortcut does it throw an error? Would like to create a stable image for everyone since theres some folks on other forums like the Jeep forums also interested it sounded like.
ahh ok, that's typical behavior then, make sure you have your micropod connected, plugged in & passed from the host to the VM or that happens.
Just curious, what makes a micropod different from a CAN plug or ODBII plug. I tried comparing the pin outs from this diagram from the 2005 manual and the diagrams listed in the link below. I see there is a bunch of SCI transmit on the data link connector. I thought they used a common bus and address devices.
Data link connector
oobd2-pinout
Data link connector
oobd2-pinout
Micropod is setup to switch which pin it is talking to for K-Line diagnostics. Each SCI line is actually a segregated K-Line. They did not put all the units on a common J1850 bus like the "regular" Chryslers did, in an attempt to keep the systems separated, and not clog up the already super slow communications.
The Micropod handles switching the K-line around to the other pins, which is what makes it 'better' or more specialized over other J2534 devices. Micropod also handles J1850 VPW Chryslers of the era, and CAN bus cars that came in 2006.
edit: Crossfires do not have CAN bus out to the diagnostic connector. It can be added, but functionality is a bit 'specialized', and not particularly useful for 99% of the users here. 2088 model year required CAN diagnostics in the US, so it may be brought out to the connector in 2008, but I have never looked at the 08 wiring diagrams. For most CF owners, CAN diagnostics are not how their cars work, despite there being more than one CAN network in the car (2 in 2003-04, 3 in 2005+)
Thanks again, sincerely
-Jerry
PS. my setup was ASUS X555Q running windows 11 and vmplayer 17.0
maxcichon
43
05-29-2022 11:43 AM
jefftalexander
01-25-2013 03:14 PM
