Let's discuss the key fob transponder chip(s)
Old Dec 29, 2018 | 10:42 AM
  #81 (permalink)
Jim Holian's Avatar
Default Re: Let's discuss the key fob transponder chip(s)
Padgett - The photo is good information. I've never seen a "valet" key for any car. Is there a chip inside the black base of the key? Since this key either bypass's the SKREEM or communicates with the SKREEM, allowing the car to start and run, it may be the answer we've all been looking for. Any idea's, anyone?
I look forward to your report on the chip's and tool that you mentioned above. Let us know how it works and if it is successful.
Jim
Old Dec 29, 2018 | 10:56 AM
  #82 (permalink)
Originally Posted by CL770
Hi
For anyone that wants to experiment with making/duplicating their Crossfire keys. The correct blank chip to use is a PCF7935AA
Like these ones on eBay: https://www.ebay.com.au/itm/10PCS-PC...s/172143666760
You can program them with this: https://www.ebay.com.au/itm/OBD2-Min...w0E9:rk:1:pf:0
Have fun!
Is there any safety that somehow stops the garage or whatever that takes your car from you from cloning your key?
Originally Posted by Padgett
OY.
Ok I have received the five RFID chip. Programmer from eBay should be here on the 8th. The "valet key" below can manually open the door or trunk and operate the ignition/start/run the car.It just has no remote capability.
By the muddle of January I should be able to answer other questions.
Anyone know where I can get just a circuit board ?
Where did you get this key from? They are not listed in any Crossfire literature I have seen. It should not open the trunk, gas cap or glove box, or does it?
Old Dec 29, 2018 | 11:09 AM
  #83 (permalink)
RED DOG's Avatar
OY
I can send you a brand new OEM key fob circuit board. PM me your address.
Old Dec 29, 2018 | 11:26 AM
  #84 (permalink)
Why can’t we duplicate this circuit board? It is not quantum physics or what ever that is.😜
Old Dec 29, 2018 | 11:47 AM
  #85 (permalink)
I think it's more like string theory, somewhere in the 5th dimension.
Anything to do with those angry pixies running around is pure magic to me.
Old Dec 29, 2018 | 03:25 PM
  #86 (permalink)
I do not think copying something like this can be too hard, reverse engineering is a compulsory class in the 8th grade in China.
Another class is designing packaging for products that are nearly impossible to open.
Old Dec 29, 2018 | 06:49 PM
  #87 (permalink)
RED DOG's Avatar
Why can’t we duplicate this circuit board? It is not quantum physics or what ever that is.��
Hi Dave, Respectfully, I think you're confused about the function of the circuit board in the key fob. My belief and experience is that the key fob circuit boards are "generic" and can be programmed to any Crossfire so as to lock / unlock / sound the panic alarm (but not to start and run the car) The circuit board is not tied to the SKREEM (disabler) module and is not tied to the "chip" in the key fob that is needed to start and run the car. A working circuit board from any OEM Crossfire key fob (old or new) can be (re)programmed to to work with another Crossfire. I'm not positive about the circuit boards that come with those "cheapie" key fob replacements (the black ones readily available on E-Bay) as my experience with one of those was that I could not program their circuit board to my Crossfire. Maybe someone else can chime in if they were successful in programming the circuit boards on those black replacement key fobs.
Old Dec 29, 2018 | 07:25 PM
  #88 (permalink)
Hi Dave, Respectfully, I think you're confused about the function of the circuit board in the key fob. My belief and experience is that the key fob circuit boards are "generic" and can be programmed to any Crossfire so as to lock / unlock / sound the panic alarm (but not to start and run the car) The circuit board is not tied to the SKREEM (disabler) module and is not tied to the "chip" in the key fob that is needed to start and run the car. A working circuit board from any OEM Crossfire key fob (old or new) can be (re)programmed to to work with another Crossfire. I'm not positive about the circuit boards that come with those "cheapie" key fob replacements (the black ones readily available on E-Bay) as my experience with one of those was that I could not program their chip to my Crossfire. Maybe someone else can chime in if they were successful in programming those black replacement key fobs.
I think you have misunderstood what I am trying to achieve.
I realize that the circuit board is just for opening the doors, the trouble is getting one. If we can train a chip and cut a key all we need is a circuit board to complete a fob that works on our cars. Simple.
Old Dec 29, 2018 | 08:50 PM
  #89 (permalink)
Padgett's Avatar
OK AFAIK the Mercedes R170 and the Crossfire Keyfob are the same. Anyone know ?
Old Dec 29, 2018 | 09:26 PM
  #90 (permalink)
CL770's Avatar
Yes it's the same key. A lot a Mercedes cars from the same era used these keys. Search for a "KR55" key. There's two systems, right hand drive cars use a 2 button key and SKREEM that work at 433MHz, left hand drive cars (USA) use a 3 button key and SKREEM that work at 315MHz.
Old Dec 30, 2018 | 10:28 AM
  #91 (permalink)
OY.
I await news of the outcome, I like excuses to buy gadgets like this.
Old Jan 11, 2019 | 10:41 PM
  #92 (permalink)
Padgett's Avatar
Zed-Bull program:
OK now have the programmer and can read a fob but the instructions are in mock-swedish and I an not sure what half of the buttons are for. Is there an English version ?
OK so gave up on the PC for the moment and just used the device. Results were frustrating. Went through the process for cloning original had a bunch of data and Type 33.
Cloned new chip, everything verified with same data and same type..
Tried in car - no go.
Read chip. Now has correct data stream but "Type: Blank Philips"
Went through the process there more times. Verified Type 33 after writing but when I read the chip it is "Type Blank Philips" and does not work.
Does anyone have one of these programmers and does it work. Am I missing something ?
Old Jan 12, 2019 | 02:30 AM
  #93 (permalink)
maggy55's Avatar
Try here, https://www.yumpu.com/en/document/re...lpdf-jinghang-
Old Jan 12, 2019 | 01:48 PM
  #94 (permalink)
Padgett's Avatar
Here is the problem. In the first picture I have read the existing key.
In the second the new chip has been read and verified.
In the third I have read the new chip again and now the TYPE has changed to blank. What am I doing rong ?
ps after two starts the "Data" has not changed.
Old Jan 12, 2019 | 02:09 PM
  #95 (permalink)
I saw YouTube videos, I’ll find them again and post them.
CLICK
Old Jan 12, 2019 | 03:07 PM
  #96 (permalink)
Padgett's Avatar
Found a bunch but not code 33 Mercedes.
Old Jan 12, 2019 | 05:05 PM
  #97 (permalink)
The first chip shows PCF7930, second picture PCF7935. Have no idea if that makes any difference?
Old Jan 12, 2019 | 05:24 PM
  #98 (permalink)
The original post by CL770 said to get the PCF7935AA chip, your first photo shows PCF7930AA.
Should you have purchased the PCF7930AA chip?
Old Jan 12, 2019 | 08:48 PM
  #99 (permalink)
Padgett's Avatar
I did purchase the -5, the first photo is where I read the data from the existing/working key.
Just ordered some 7530s but may be the end of the month. They do look more like the one I removed from the damaged but functional fob.
Old Jan 12, 2019 | 09:04 PM
  #100 (permalink)
The first picture says ,,,,,,30.}
