Water pump going bad?
Old Dec 20, 2018 | 05:06 PM
Tom3120's Avatar
Default Re: Water pump going bad?
For anyone that has flushed and replaced the coolant......the manual says it holds 11.8 quarts. I'm probably not going to be able to empty the coolant from the block but I don't know how much that would hold. Would I need to buy 3 gallon (12 quarts)....or is 2 gallon (8 quarts) enough?
I'm assuming I will buy the Zerex G-05 50/50 premixed. Is there any reason to get the concentrate instead of the 50/50 premix? I'm in Indiana (if that matters).
Old Dec 21, 2018 | 08:00 AM
The concentrate Zerex G05 gallon + 1 gallon of distilled water costs almost the same as the one gallon 50/50 and you have twice as much.
Old Dec 21, 2018 | 10:39 AM
On Amazon, 1 gallon of concentrate is $16.99 and 2 gallons of premix is $22.26. I am sure that 1 gallon of distilled water can be had for a lot less than $5.27. Remember to dispose of the old fluid properly as this stuff is not eco friendly, and painfully kills animals who are drawn to the taste of it.
I think that I purchased 2 gallons of each when I did my system.
There is a How To on the method to do the job by James1549 (CLICK HERE), I never bothered to change the thermostat but on a higher mleage car it might be worthwhile though.
Old Dec 21, 2018 | 10:45 AM
The site I looked at had only a $2 difference. I can buy distilled water here for $1 per gallon.
So, you get the extra gallon for $3.
Old Dec 21, 2018 | 06:44 PM
Tom3120's Avatar
I want to thank you guys for your advise and input. I have the parts ordered and notes taken. Not sure if I will do this soon or wait until springtime (warmer weather) to do it but I feel confident about doing this myself. Actually kind of looking forward to doing it. Should be a satisfying experience to complete the work and know that the car is better and saved some $$ as well.
Old Oct 30, 2019 | 07:28 PM
TheStig's Avatar
My water pump just took a ****, and it appears the front crank seal was compromised in the process. Does that seem normal?
Old Oct 30, 2019 | 11:58 PM
Originally Posted by thestig
my water pump just took a ****, and it appears the front crank seal was compromised in the process. Does that seem normal?
no...
Old Oct 31, 2019 | 11:03 AM
Toolman's Avatar
no...
I second that opinion.
Old Oct 31, 2019 | 11:08 AM
TheStig's Avatar
Ok... Maybe not normal but Is it possible? Maybe when the pump finally gave out it put a lot of stress on the belt or something? Haven't had a chance to dig into it yet, but the water pump pulley is crazy wobbly and there is a good amount of oil that started leaking at the same time and same area of the engine
Old Apr 24, 2025 | 12:26 AM
Bumblebee's Avatar
Wink Re: Water pump going bad?
Originally Posted by waldig
bolts are ;many different lengths, remove and set them in the new pump on the ground. Remove the pump and swap bolts to old one, and reinsert as new pump is installed. They are screwed into aluminum and different lengths. You have been told, dont ask me how i know. Woody
i did find out the hard way too, although i thought i put them in squence on a cardboard 🙄
BlkBuLL crossfire
Dec 17, 2018 11:13 PM
velociabstract
Oct 29, 2012 01:41 PM
HowardJ
Apr 6, 2010 10:00 AM
askmenomore
Feb 3, 2010 12:56 PM
Goldwing
Aug 14, 2009 02:45 PM
